» Sponsors
» Sponsors
Old 08-14-2009, 09:39 PM   #1 (permalink)
nmc1205's Avatar
Default foggy instrument cluster
Hi does anyone have any fix ideas to cure a foggy instrument cluster? Do I need to remove the bezel or is there another easier cure. Thanks
there is just something about the smell of ep 90 gear oil when driving a land rover. Best perfume around.
nmc1205 is offline   Reply With Quote
Old 08-15-2009, 07:13 AM   #2 (permalink)
antichrist's Avatar
The seal in the bezel is probably dried and cracked.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 08-15-2009, 08:41 AM   #3 (permalink)
Smokey Mountain Man's Avatar
The bezel and lenze are easy to romove. Just turn it until the teeth line up in the back and it should pop loose. i am not sure where you can find a new O-ring.
Smokey Mountain Man is offline   Reply With Quote
Old 08-15-2009, 09:34 PM   #4 (permalink)
nmc1205's Avatar
thanks everyone. It appears that it was removed in the past and caulked into place. I will attempt to clean it up and build an o-ring/ gasket. Thanks a lot for the help.
1975 RRC instrument cluster diagram Populus Range Rover Classic 2 07-11-2009 04:36 PM
Pictorial - instrument cluster removal '99 Disco II tyl604 Discovery Series II 0 11-24-2008 09:34 PM
Need diagram to remove instrument cluster 2000 Disco II tyl604 Discovery Series II 6 11-21-2008 12:35 PM
96 Disco Instrument Cluster Circuitry Beluga96 Discovery Series I 7 02-08-2007 05:22 PM
Instrument Cluster Replacement asterix Discovery Series I 4 10-15-2005 09:52 PM
