Old 01-31-2005, 07:29 AM   #1 (permalink)
Geobloke's Avatar
Question It be Freeeeezzzin over where you are??!?!?! HELP!!!
Hello peeps across the pond!
I have a friend who is moving to Maine and taking his SIII with him (of course!!). He would like to fit some sort of engine, coolant heating device/devices.
What can you suggest? and where can he get them? What do you lot use?
Cheers
Geobloke
Geobloke is offline   Reply With Quote
Old 01-31-2005, 07:55 AM   #2 (permalink)
I would install a block heater into the block under the exhaust manifold,if it is fitted for it.If not you could install an in-line heater into the lower rad hose.Sometimes a battery blanket can be helpful on those cold days.Please make sure that you have at the very least 50-50 water/antifreeze mixture in the cooling system.Good luck.
Long live the oily beast.
s3landy is offline   Reply With Quote
Old 01-31-2005, 08:22 AM   #3 (permalink)
Bogatyr's Avatar
There are also options like the magnetic sump heater...stick it on the oil pan, plug it in and let it work...not sure how long they should remain on though...block heaters and inline hose heaters are other options. I know RN sells the hose heater, Wise Owl sells the block heater and pretty much any parts shop will sell the magnetic doodad...
Bogatyr
Current Rover Fleet:
Old 01-31-2005, 09:06 AM   #4 (permalink)
TerryS's Avatar
I spent most of last week in Greenville Maine. Next to Old Forge, NY, it's about as cold a spot as one can find, though a town in MN had -56 F (that's not wind chill either, two weeks ago) Wind off the lake makes wind chills sink to the -40 to -50 range) Most mornings were -10 F, or lower. I took the disco, only because the 110 is like a freezer and cabin insulation sucks at best. I prefer an inline water heater because of simplicity of installation. Block heaters inserted into freeze plug openings work as well, but often develope a leak and need tightening of the seal, when there are radical swings in the temp. They're not especially accesible if you need to get at them. Both the block heater and the in-line hose heater provide enough heat to dramatically reduce warmup time, though do nothing to keep the sump oil fluid. The hose heater, being installed lower down in the system seems to cause good thermal circulation. A friend had a sump heater way back when and insisted it 'cooked' his oil. Deciding technology had advanced, invested in a newer magmount unit, and promptly lost it the first time out in roughish terrain.
Old 01-31-2005, 09:43 AM   #5 (permalink)
Geobloke's Avatar
Talking
What a brill responce! Now do any of you know any websites he can go and have a look at?
Cheers
Geo.
Old 01-31-2005, 11:21 AM   #6 (permalink)
TerryS's Avatar
Originally Posted by TerryS
They're not especially accesible if you need to get at them. .
After I said this, I thought I might be getting a little forgetful. I have been driving some sort of V8 LR for so long now that I forgot my roots in the marque, that being S2A. Block heaters in those are much easier to get at than the V8, whose freeze plugs are below the exhaust manifolds.
Websites? OOOh yeah, lots of 'em. Some for just window shopping toys, others more usefull for the DIYer, Rovers North (with seperate bbs for series folk, which always struck me as odd, since Series folk have more in common with Def folk, than do Rangie and Disco, at least in my naturally unbiased eye) has a good BBS, Rangie.com for the RRC peeps, and Discoweb.org, if it ever comes back up again.
Last edited by TerryS : 01-31-2005 at 11:22 AM. Reason: because I can't type, that's why !
Old 02-01-2005, 11:56 PM   #7 (permalink)
Here in Alaska, our common methods for winterizing vehicles are those mentioned above...block heaters, battery blanket, etc. An easy way to keep your engine oil in the pan warmed are those little orange rubber pads that have an electrical cord on them. Up here, they are just sold as Oil Pan Heaters, so I don't know what they are called elsewhere. We also use them to stick under batteries for cheap warmer and they do very well glued to a plastic bucket for a dog's water dish warmer.
Esha is offline   Reply With Quote
Old 02-02-2005, 02:54 AM   #8 (permalink)
Default freezing???
A very interesting read, the coldest I get here in winter is about 4-5 celcius, that is not even near below freezing. It is interesting to read about the experiences landy owners will put up with to indulge their passion of driving landrovers. Keep the questions coming. PS here is subtropical Australia.
Strazzman is offline   Reply With Quote
Old 02-02-2005, 11:00 PM   #9 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
John
I agree. I cant believe that you actully need to have a heater to warm up your oil and battery!!
The coldest we get her might be about -10Celcius. BUT THAT IS THE EXTREME AND ONLY IN THE MOUNTAINS.
Averige coldest for the rest of the place is about 0 celcius.!! (And then we all die!!)
My Landy dont even have a heater! I dont need one. Nothing a wark cup of Coffy cant heat up.
Moeras is offline   Reply With Quote
Old 02-03-2005, 06:10 AM   #10 (permalink)
yo mama
Jonesy's Avatar
'ang on a minute - how come he can bring his SIII in here but we cant???? Anyone know the rules????? I know it is beyond difficult to import one in here according to a post I had. Is it because he is the owner in the UK?>?????
Jonesy is offline   Reply With Quote
Old 02-03-2005, 06:56 AM   #11 (permalink)
TerryS's Avatar
He said his friend was moving to Maine, but didn't say 'from the UK'. That notwithstanding, any series III, built before Feb, 1980 (making it over 25 years old) can be imported no problem. Since they came out in 1972, thats 8 years of series III eligible for importation.
Old 02-03-2005, 09:18 AM   #12 (permalink)
Geobloke's Avatar
Talking
The man is correct! as it happens his SIII is a 1971 vintage and is made up of a mixture of SII and SIII parts, kind of the cross over period between the two models. Using up the LR parts bin!
Old 02-08-2005, 12:08 PM   #13 (permalink)
moses's Avatar
Talking It's me.
Hey Guys,
I finally got the link for this forum so I can post directly, cheers Geo.
By the time I get my truck exported to the US I think you will just have standard cold weather, rather than the extream struff, so I'll just make do this year and see how it goes. Cheers for all your suggestions, it'll give me plenty to think about and play with for next winter.
I'm just sorting out my shipping documents at the moment, and can't wait to start driving on the wrong side of the road.
Cheers,
Moses.
moses is offline   Reply With Quote
Old 02-08-2005, 01:44 PM   #14 (permalink)
It depends on what part of Maine you are moving to. The coastal area does not get as brutally cold as inland. I have 0/40 Mobil 1 and she starts up fine even at 0º F. Does take awhile for the heat to start.
So, what part of Maine???
Kevin
88 RRC "Audrey"
Kevin88RRC is online now   Reply With Quote
Old 02-09-2005, 03:05 AM   #15 (permalink)
moses's Avatar
Hi kevin,
I'm not entirely sure of a town yet, but it'll be around the Bangor/Orono area.
I'll staying with friends in Orono for a while untill I get my own place sorted.
I've traveled through Portland on the bus up from Boston, so you're about 2.5 hours south, yes? Maybe you could point me in the direction of a good Mechanic/Garage? Any offroad/greenlaning clubs in the area?
Cheers,
Moses.
