Links
Old 01-16-2008, 07:39 PM   #1 (permalink)
Nic
Nic900's Avatar
Default Fuel under pressure question
I have noticed that on the several recent occasions that I have had to disconnect the fuel line from the carb, fuel has shot out of the line under pressure, enough to send it several feet. I do not recall this doing this on the first time I had to take this pipe off. Is it me or does this not sound right?
Once again thanks in advance for your help and comments.
Nic
What happens if I turn this .....oh
Nic900 is offline   Reply With Quote
Old 01-16-2008, 08:01 PM   #2 (permalink)
Sounds right to me. Your fuel pump produces 4 to 6 PSI and has a check valve preventing it flowing back into the tank. When your float bowl is full, the needle valve shuts it off on that end; you're left with pressure in that line!
Greg S is offline   Reply With Quote
Old 01-16-2008, 08:14 PM   #3 (permalink)
Nic
Nic900's Avatar
Excellent! As there is nothing to fix there I'll check my list to see whats next on the "broke" list
Cheers
Nic
Fuel pressure drops to zero after shutoff, hard to start warm. atikovi Discovery Series I 14 04-11-2007 05:07 PM
P38 Fuel Pressure & Code P1179 ikoinu Range Rover P38, Mk III and Range Rover Sport 6 02-18-2007 03:02 PM
Fuel Pressure Regulator bad? wade Discovery Series I 1 05-18-2006 07:52 AM
fuel pressure regulator!! Lucasfree Range Rover Classic 1 02-19-2006 08:09 PM
No Fuel Pump Pressure skyhawk Discovery Series I 13 04-06-2005 09:15 PM
