#16 (permalink) |
Ian Matthews
You can try these links for the newer version of the TDi.
2.8L Tdi POWERSTROKE - International 2.8L HS - LandyOnline Workshop NZ 4WD Site Magazine Publishing, Magazine Subscriptions, Back Issues, Trade Magazines - NZ 4WD Site Publishing Ltd DiscoWeb Bulletin Board: 2.8 Powerstroke Questions |
#17 (permalink) | |
I wouldn't go more than the 200tdi. Even my Perkins 4203 is too much torque for the SIII gearbox.
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
#18 (permalink) |
Ian Matthews
Another TDi conversion write-up for you
Series III 300 Tdi Conversion You Should note the following statements at the end: "the 300 Tdi into a Series Land Rover (Series II, IIA, III) requires the following: 1. Coil sprung chassis. We do not install the 300 Tdi 5 speed into a leaf sprung chassis for many reasons. Some (but not all) being: -Axle strength. The Series axles won't stand up to Tdi torque. The Defender axles in the coil chassis will. -Steering. The Tdi requires PS. This is much easier on a coil chassis than a leaf chassis, although it can be fitted as a separate system on a leaf sprung Rover. -Brakes. The coil chassis have 4 wheel disc brakes, while the Series Rovers have 10" drum brakes (88"). We don't feel these vintage drum brakes are up the the power and speed that the Tdi can put out, so we require the 4 wheel discs. -Clearance above the front diff. The added clearance of the coil chassis is needed to clear the Tdi's engine placement. 2. Power Steering. The location of the turbo on the 300 Tdi makes it impossible to fit a stock Series steering box. PS must be fitted. 3. Body work. A Rover with Series III or "late" Series IIA front bodywork can have a Tdi fitted. The early Series IIA bodywork (pre-1968) can not. The headlights in the grill take up space needed for the radiator and intercooler. See the engine bay images above to see how tight things really are. However, if you were to fit Defender style front bodywork to your Series Rover (Series II,IIA,III), the conversion would be much easier and could be done at reduced cost. The other required items still apply, but the Defender front body work reduces the custom work by about half. 4. Gearbox. The 5 speed gearbox must be fitted for the Tdi. The torque of the Tdi would break the stock Series gearbox. |
#19 (permalink) |
jimfoo
The Disco 200 TDI is a harder swap as the turbo sits down low by the frame rail and somewhat close to the tire when turning. The Defender 200 TDI is better for a conversion.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
#20 (permalink) |
frack
i was thinking about putting the 2.8td diahatsu in my 109 would you recomend it ? what gear box have you mated to yours . do you think it would be ok on standard leaf springs??? what mpg etc
thankyou |
| Thread Tools | |
| Display Modes | |
| DI Diesel Conversion | AZROVER | Hybrid | 5 | 08-04-2008 03:58 PM |
| Isuzu Diesel conversion - new Torque Converter? | adcomp | Hybrid | 0 | 12-13-2007 07:42 PM |
| Vancouver Diesel Conversion ? | Indanao | Canada | 1 | 09-29-2007 04:32 PM |
| Diesel Conversion | DickFox | Series Land Rovers | 5 | 05-02-2006 06:56 PM |
| Springs for Diesel conversion | Richie_asg1 | Series Land Rovers | 1 | 03-19-2006 03:26 PM |
