Old 05-14-2008, 03:04 PM   #1 (permalink)
dsfloyd's Avatar
Question Gl-4
I can't find this gear oil any where. Everything is GL-5. I know the GL-4 is needed for the gear box because of corrosion. Does anyone know where I can get it? I am holding out hope that NAPA will cary some. Is the transfer case and everything else fine with the GL-5?
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 05-15-2008, 01:17 AM   #2 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
napa sells a generic gl-4 in a gallon? bottle.
royal purple and lucas make non corrosive gear oils as well but they aren't labled gl-4 they just "meet gl-5" well they're all backwards compatible.. cept for the corrosives in gl-5.. which is strange.. arent there still yellow metals (brass bronze) in t-5s and some non carbon t-56s..
the GL-4 is only important because it can slightly corrode yellow metals (your syncros and maybe bushings).. SO.. something labeled "non corrosive" or gl-4 gl-3 will do
It looks like gl-5 will be fine in the transfer case/overdrive. I don't see any brass parts at a glance.
Its not super corrosive.. but it may be why mine has failed at 126k
THen again.. they're junk transmissions in series trucks.
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Old 05-15-2008, 08:04 AM   #3 (permalink)
polar's Avatar
Amsoil https://www.amsoil.com/storefront/svg.aspx
makes a GL-4 specific Gear Lube.
Also Redline MTL is a GL-4.
2002 Discovery 4.0 55K
Delo 400 5W-40 synthetic
CI-4 PLUS, CI-4, CH-4, SL (SAE 5W-40)
Zinc=1310
Phosphorus=1560
polar is offline   Reply With Quote
Old 05-15-2008, 06:41 PM   #4 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
My feelings on the redline and especially amsoil products...
Your lubricants should never out-value your vehicle..
It lasted 30-60 years on plain dinosaurs.. now-a-days.. even the non synthetics are chock full o additives making them totally different than they were 10 years ago... those premium race oils are good products.. but overkill.
the napa oil isnt 20 bucks a gallon
Old 05-16-2008, 01:57 PM   #5 (permalink)
dsfloyd's Avatar
Thanks but I'd have to agree with Zed. I will possibly run some synthetics in my other vehicles (required in my trucks rearend), but definately sticking to cheap dino oil for the series.
'60 Series II 88
Old 05-16-2008, 06:18 PM   #6 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
oh yes.. I do run synths in all my close tolerance high pressure newer vehicles they ask for it if not require it.... Don't get me wrong I love synthetic oils. But the rover doesn't need it or want it. Till I build a funny-car.. i'm not using lucas or redline.
