Our headlights on 1971 IIA are dimmer at idle and brighten up when rolling - not a huge amount, but enough to be noticeable. What causes this and would relays fix it ?(our headlights are GE halogen form one of the LR vendors). If so, what relay should we use and tips on where in the line to install. If not, could it be an alternator/slow idle issue (550 rpms)?
Thanks, Greg |
#2 (permalink) | |
If you want you can adjust the idle a bit (speed it up), but in all honesty i'd leave it as it is. Check that your belt is properly adjusted too, should be about 10mm play in the belt either way (up and down).
1992 K-reg 200TDI Defender 90 (Eva) MSN - Geobloke@hotmail.com There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill |
Relays are always a good idea especially when running hologens (now that being said, I still have not gotten my relays installed.) The wiring on these old truck is yes old, and also when new, they were almost at max capacity. The relays are easy to instal.... Use the existing wires to power the relay, run new wires from a power block to the relay, and then from relay to the headlights. Then when you flip the switch, the old wire is carrying only the amount of power needed to turn on the relay, and the new heavier wire is carrying the power for the headlights.
As for the dimming, I am trying to remember an old rover that did not brighten up when running at speed. I tend to have my idle set higher as I drive in stop and go traffic, and it is easier to feather the clutch at higher idle ( I can almost take off from a standstill on a bit of an incline without touching the gas.... )
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
The Best 4X4XFar
yep perfectly normal for almost any car that's 30 years old+ in design.
Bigger alternator and/or battery may help out. Bet if you put your indicator on while idling with the lights on the relay is really slow, up the revs a bit and lights will brighen and the indicator flasher speeds up.
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
Okay, as long as normal and not indicating some problem we decided to leave as is for now. We are adding some driving lights soon that have relays, so we will see how they hook up and may add them later as pickuprover suggests.
Thanks! |
