Hello! Brand new here, delighted to be. Writer and artist; lover of Land Rovers since...infancy? On the verge of local purchase of Series IIA, '70, really good shape,88,third owner, farm and southwest use, removable hard top (8 bolts); Koenig winch; Webber carb; alternator conversion; rust free, interior in excel. cond. $8500 US. Owner says only does about 55mph tops; anybody know what I might be in for? Looks very sweet from pictures, will drive this weekend. Happy New Year
freespirit,
Keep in mind that series trucks need more attention than your usual vehicle. They can be tempermental, thirsty, leaky and noisy, but there's nothing like them on the road. Sounds like a fair price for a rig in decent condition with an ok frame. 55mph is normal top speed without an overdrive. Being a 1970, you'll need to double clutch in first and second gears. It's most important to check the frame and firewall for rust. Mechanical things can be fixed relatively easily, but if the frame is shot, or the firewall is toast, you're looking a major time/money to fix. Not sure what your goals are, but just keep that in mind. Bang all over the frame with a hammer, especially near the spring perches and outriggers. No oil leaks means it's out of oil. You might want to do a compression test...especially if the truck feels like a total dog... Try low and 4wd, brake panic stops, and the rest of the stuff you would normally do when checking out a vehicle. Pop off at least one drum to look for oil seals gone bad... I'm prolly missing stuff, but that might give you a good start... Bogatyr
Current Rover Fleet: 1996 D1 120k (finally on the road) 1970 IIa 88" (the running one) 1970 IIa 88" (parts truck - need any parts?) 1966 IIa 109" (next project...) |
At $8500 it must be in really good shape. On the other hand, when I was shopping, it wasn't a case of which one would 'do' or be 'good enough', it was more like "Is it sold yet?", then if the answer was no, I'd have to say "I'll take it." You have to admit, there aren't too many Land Rover Series vehicles for sale on this continent. I picked up a 1970 109 SW 7 years ago and am happy with it. I had 30 years of poor service work to catch up with and, of course, damage I did myself on & off road. I've put 100,000 miles on it in that time. You have to expect to do the repairs yourself or you will go broke, because whatever mechanic you take it to, has probably never seen one before (this includes brake shops, muffler joints and tire shops) so the mechanic will have to do the "green bible" reading and trial and error learning, all on your pocket book. They are made very simple (the Land Rovers is what I'm talking about here) and are easy to work on for the novice BUT they don't meet all the rules other cars used when being put together so trained mechanics are driven nuts trying to figure them out. They usually are too proud to listen to the owner or read the manual too. ("I' bin fixing cars fur 30 years! I ain't gunna read no manual, and who are you to tell me how tu do it?")
If you buy it, and I think it is a great idea, make sure you buy a factory workshop manual and plan on getting your hands dirty. For $8500 the motor should be flawless as should the transmission. Remember, It likely will have NON-syncro in 1st & 2nd gears. Watch your knee when getting in or you'll be putting an ice-pack and bandage on your knee from it hitting the turn signal bracket. When driving, you'll learn REALLY quickly to keep your elbows close to your rib-cage, or else you'll be using that ice pack on your left elbow because it will have been trying to dent the door when you were turning. Truely a wonderful machine and a 1970 is the best of the best. It still has the metal dash and simple lay-out. The late 2A transmission is considered more robust than the early series 3 or earlier series 2 and 2a units, it has the more conventional (to you and I) ignition key and starter. It will have mounts for shoulder harnesses for the seat belts and probably door mounted mirrors. Keep in touch! Any questions you need to ask will have people ALL OVER THE WORLD answering them, and all for free, not like on some automotive web forums. Greg S |
