#16 (permalink) | |
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
#17 (permalink) |
Nut Futzer
I read "fully adjust transmission brake to stop the transmission from turning", probably under some other procedure.
I found a way to do it tho. I wrapped a nylon web strap (like a tow strap) around the output then around my workbench leg. I turned the bolt against the strap tightening on its self. Worked just fine, and I didn't have to open the box top again. Reverse the wrap to tighten. |
#18 (permalink) |
Nut Futzer
BTW, just took it up and down the street on P-Brake, as I still don't have the new MCL.
I just got up to maybe 20 and as I pushed in the clutch to stop and back into the driveway. It popped out of second. I guess it does need that rebuild. Tightening the nut on the back didn't do anything. It seems to be getting worse quickly. Maybe it's my imagination. ANYWAY. I ordered all the gaskets to do the transmission swap. They didn't send me all the gaskets I wanted, but I ordered them. Time to re-order the one they missed. Need a couple tools as well. But, I'll drive it enough to get it inspected and on the road once the mirrors and MCL are in. |
#19 (permalink) |
jimfoo
Personally, I'd just use "The Right Stuff", available at Napa, instead of the paper gaskets unless you want leaks. That's what I did on my tranny, and it was the only thing that didn't leak on the Rover. Just use it sparingly as you don't want big globs oozing inside.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
#21 (permalink) |
Nut Futzer
the 3 housing goes neatly onto a 2/2a
did it.. its done.
"Its a beautiful thing the destruction of words" “Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.” - Orwell: nineteen eighty-four, true for Oceania, true for today. |
| Thread Tools | |
| Display Modes | |
| SIIa/III Gearbox | 01001010 | Series Land Rovers | 16 | 01-19-2008 08:29 PM |
| SII to SIII gearbox? | rupertmja | Series Land Rovers | 7 | 07-28-2007 07:41 PM |
| Synthetic gearbox oil | fish | Accessories | 22 | 10-14-2005 09:34 AM |
| LR 90 LT77 gearbox oil improvements | Timil | Defender | 2 | 05-04-2005 12:35 PM |
| 93 Disco Engine/Auto Gearbox running hot | bobbie+chris | Discovery Series I | 6 | 04-26-2005 03:31 PM |
