Old 08-01-2008, 11:17 PM   #1 (permalink)
archaeology_student's Avatar
Gallery: 7
Question Indicator lights stuck on
Howdy,
I was wondering about my indicator lights and an issue that happens randomly. Sometimes when I indicate that I am turning the indicators do their job, but then other times they do not.
Symptom:
Indicator lights stay on almost like they are stuck. I have gotten out, and looked at the lights, and they are all "on" and do not blink depending on which set of indicators I am using (i.e., left turn or right turn).
It's a nuissance when I get to intersections and they are not working properly... my simple solution is to use the switch repeatedly until I turn, but that gets tiring. So, where do I start?
Cheers, and thank you in advance
Yup, I run BioDiesel in my Series
MSN Blog with LR info and Photos
archaeology_student is offline   Reply With Quote
Old 08-02-2008, 05:00 AM   #2 (permalink)
pickuprover's Avatar
I would check the flasher unit first.... also check to make sure all your lights that are supposed to be flashing are on. My unit will not flash if either the front or the rear light bulbs are gone.
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is online now   Reply With Quote
Rear Hatch Door Stuck Rookie Discovery Series II 6 06-26-2008 03:40 PM
If your key gets stuck in the ignition, do this etischer Tech & DIY 2 08-06-2007 11:44 AM
Tape stuck in radio-Mode stuck on “tape” Kris Range Rover Classic 2 01-28-2007 09:03 AM
'93 Range Rover emergency brake stuck trellis8 Range Rover Classic 6 07-03-2006 09:57 AM
88 ways to tell you're stuck in the 80's apbtpetey The Lounge 35 01-20-2006 11:23 PM
