Howdy,
I was wondering about my indicator lights and an issue that happens randomly. Sometimes when I indicate that I am turning the indicators do their job, but then other times they do not. Symptom: Indicator lights stay on almost like they are stuck. I have gotten out, and looked at the lights, and they are all "on" and do not blink depending on which set of indicators I am using (i.e., left turn or right turn). It's a nuissance when I get to intersections and they are not working properly... my simple solution is to use the switch repeatedly until I turn, but that gets tiring. So, where do I start? Cheers, and thank you in advance ![]() |
I would check the flasher unit first.... also check to make sure all your lights that are supposed to be flashing are on. My unit will not flash if either the front or the rear light bulbs are gone.
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
| Thread Tools | |
| Display Modes | |
| Rear Hatch Door Stuck | Rookie | Discovery Series II | 6 | 06-26-2008 03:40 PM |
| If your key gets stuck in the ignition, do this | etischer | Tech & DIY | 2 | 08-06-2007 11:44 AM |
| Tape stuck in radio-Mode stuck on “tape” | Kris | Range Rover Classic | 2 | 01-28-2007 09:03 AM |
| '93 Range Rover emergency brake stuck | trellis8 | Range Rover Classic | 6 | 07-03-2006 09:57 AM |
| 88 ways to tell you're stuck in the 80's | apbtpetey | The Lounge | 35 | 01-20-2006 11:23 PM |
