Old 01-06-2006, 01:43 AM   #1 (permalink)
Question injec pump change
hi
just want to no is the injec pump on my 2 1/4 just the same to change as a dizzy in a petrol car i see it runs on a one way fitting so is it sright forward to change or is ther more?
log burner is offline   Reply With Quote
Old 01-06-2006, 08:03 PM   #2 (permalink)
Series Moderator
onslow's Avatar
pretty much the same as a dizzy except for bleeding and such, it will only locate in one position in the drive dog
Old 01-06-2006, 11:05 PM   #3 (permalink)
thanks
Old 01-15-2006, 04:13 AM   #4 (permalink)
Default losing faith
hi all
haveing a bad time with me landy
ive had no end of runnuing problems like fuel starve. ther was no air getting in the systom so i decided to change the injector pump carnt go wroung only gos in one way so all when in ok i bolted it down after i fitted the injetor pipes
so i would be in the same place as the old one . the pump came from a running engine so i no it was ok. i got her started but had to raise the idle
be4 she shaked to pits........ so took her on a test drive she seem slugish and still a bit smokey as if its over fueling? i will wide open the throttle stop just a bit to see how she goes or does any body think the pump timeing could be out ?........she smokes light blue shes always had a little smoke on idle until this running problem iam a lose ends hear dont no wear to look next thinking of sticking a 2.5 sherpa in her????
