Old 05-24-2008, 10:59 AM   #1 (permalink)
seriesthreedreamer's Avatar
Default leaf to coil springs
If you install coil springs in place of the leaf springs on a series three, does it affect the tax/insurance?
and is it a hefty job?
seriesthreedreamer is offline   Reply With Quote
Old 05-25-2008, 05:19 AM   #2 (permalink)
Not sure, but why not save yourself a lot of work and install parabolics. You won't be disapointed.
s3landy is offline   Reply With Quote
Old 05-25-2008, 05:23 AM   #3 (permalink)
TerryS's Avatar
Originally Posted by seriesthreedreamer View Post
If you install coil springs in place of the leaf springs on a series three, is it a hefty job?
No, unless you consider a new frame 'hefty'
Old 05-25-2008, 08:15 AM   #4 (permalink)
Parabolics?
care to elaborate?
Old 05-25-2008, 09:44 AM   #5 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
I have been told that coil springs will not go into a series... need to go defender or cut a rangeie frame to size (seen both.. nothing i would undertake).
PARABOLICs replace the too many leaf suspension. Some say they ride nicer, some say they perform off road better but don't ride any better.
If your springs are sucky (like mine) could be the leaves are rusted together. Parabolics offer more travel.. they seem like they must offer a little more springiness to them but leaves never ride nice..
If they did, you'd end up turning them wrong way round. Which does happen occasionally on lifted trucks running parabolics.
Parabolic Springs
As for tax etc.. You must be in the UK. HAwaii and Japan.. they're technically illegal.. but it doesn't effect taxes if you can get away with it. I assume you are trying to keep your tax exempt status. Can't be helping to maintain the roads or anything.
I have heard that you'll be ok with parabolics. But if not.. pay your taxes.
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Old 05-27-2008, 07:29 AM   #6 (permalink)
antichrist's Avatar
I'm assuming, based on this question, you're in the UK, or maybe Oz. You'll probably get much more advice on tax/insurance questions like this from a UK specific site, assuming that's where you are.
Here in the US there would be no effect.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 05-27-2008, 08:34 AM   #7 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
"If you install coil springs in place of the leaf springs on a series three, is it a hefty job?"
I imagine if you had a donor vehicle, you could cut the suspension mounts off and weld them to the Series frame, though you would probably have to fab some stuff up. That might be easier than a whole frame swap, but still a fair bit of work.
Jim Hall
obstacle.” Michael
Old 05-27-2008, 02:20 PM   #8 (permalink)
i'll just leave it how it is and maybe consider parabolics
Old 05-28-2008, 12:02 AM   #9 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
seriously.. you want to go through that trouble.. just pick up a defender.
Coil Springs color codes skippermccoy Range Rover Classic 3 12-05-2007 07:11 AM
Land Rover Coil Springs 88gspd Land Rover Parts and Accessories 4 09-26-2006 12:27 PM
front coil springs kennyday Discovery Series I 8 06-27-2006 05:36 PM
Disco coil springs Jaco Discovery Series I 11 08-02-2005 07:44 AM
coil springs and leaf springs indrika Off Road 2 05-21-2005 08:22 PM
