Old 07-10-2008, 07:37 AM   #1 (permalink)
Default Leak, left front wheel
HI
I have an oil leak (in a 1964 88), not from the swivel ball seal, but between the swivel housing and the break anchor plate. I have a couple pics on my blog. one more truck
Any thoughts?
No experienced LR mechanic near by, but a good one who says he can do anything with parts. I am handy (I'm a plumber), but have never worked on vehicles before (aside from oil change).
Thanks
Tom
flap is offline   Reply With Quote
Old 07-10-2008, 11:12 AM   #2 (permalink)
dsfloyd's Avatar
Nice looking truck.
I would check and see if the wheel cylinder is leaking. If not you might need to pull apart the the hub and check the seals there. Its been a few years since I have taken mine apart so off the top of my head I don't remember what seals are in there. I did the entire section when I added lockable hubs.
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 07-10-2008, 12:11 PM   #3 (permalink)
antichrist's Avatar
Scratch and sniff. You'll be able to tell if it's a hub or brake leak.
If it's gear oil it would mean you'll need a new seal, and on a vehicle that old you will very likely also need a stub axle distance piece as they often get grooved where the seal rides.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 07-11-2008, 09:05 AM   #4 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
And if it is the seal, make sure you get a double lipped seal as they last WAY longer. Distance piece gets carefully cut/chiseled off, new one gets heated up and drifted on with a piece of pipe. It doesn't hurt to put hylomar on the stub where it sits either.
Jim Hall
obstacle.” Michael
jimfoo is online now   Reply With Quote
Old 07-27-2008, 02:21 PM   #5 (permalink)
Default Fixed
Mechanic took it apart smoothed out some bumps, made a gasket and now it is tight. There was no gasket there.
Now onto other problems...
Old 07-28-2008, 04:16 AM   #6 (permalink)
antichrist's Avatar
Good deal. I have no clue what I was thinking in my post.
Your description didn't point to the hub seal.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
Help Need To Find Front Left Outrigger Help YNODISCO Discovery Series I 0 04-24-2007 03:55 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
viscous coupling? no front wheel drive?! ryanc8514 Range Rover Classic 13 07-10-2006 06:01 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
