» Sponsors
» Sponsors
Old 08-09-2009, 03:26 PM   #1 (permalink)
Default more transmission help
Greetings,
First, thank you all out there in roverland for the help you have provided with getting this 71 88 up and running.
I have managed to find an overdrive and a rare bottom PTO($ouch).
However after all this the OD and bottom pto wont fit.
I have a transmission and a transfer case out of a 1 ton. Does anyone know if there is an overdrive that fits this particular transmission? I hate to swap transmissions as it came with the rover 88 new with the hydrowinch, I was also told the winch needs this transmission to function properly.
Im hoping someone can tell me if there is a overdrive that fits this 1 ton trans and were I can get one.
Thanks
John IV
JOHNIV is offline   Reply With Quote
Old 08-09-2009, 05:21 PM   #2 (permalink)
antichrist's Avatar
No, no OD available for the 1-ton gearbox.
Have you verified the bottom PTO even works with the 1-Ton transfer case?
If you have a PTO to drive a hydraulic pump, or you have a hyd bottom PTO, then I can't think of any reason you'd a special gearbox. The hydraulic motor on the winch won't care.
Like I said in one of your other threads, I have a couple of spare SIIa complete gearboxes I'd be interested in trading for your 1-ton, as I'm building a 1-ton 109 and need a gearbox for it.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 08-10-2009, 08:50 AM   #3 (permalink)
Smokey Mountain Man's Avatar
What are the numbers for a 1ton set up? I might have one laying around and I would like to put it in my rig.
Smokey Mountain Man is offline   Reply With Quote
Old 08-10-2009, 06:12 PM   #4 (permalink)
antichrist's Avatar
Overall ratio
High Low
4th
7.19:1 15.4:1
3rd
10.8:1 23.1:1
2nd
15.96:1 34.1:1
1st
25.9:1 55.3:1
They were intended to be used with 9.00x16 tires
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 08-16-2009, 10:52 PM   #5 (permalink)
I have a winch driven from the PTO mounted on the back of the T case, right where the OD should go. I'd sure love to have a bottom PTO so I could mount an OD. I keep going on multi thousand mile expeditions and an OD would make things nicer I expect. I don't want to loose my PTO winch, even though I didn't use it on this last trip. (3900 miles, got back on the 6th from the National Rally.) Anyone here go to it?
So--- How much would you want for the bottom mount PTO? Can I afford it?
What make OD do you have? Should I afford it too?
Greg S
Greg S is offline   Reply With Quote
Old 08-17-2009, 08:35 AM   #6 (permalink)
antichrist's Avatar
Greg, if you ditch your drop down PTO unit, Koenig I assume, I'd be interested in it.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Odd transmission help needed! JOHNIV Series Land Rovers 5 07-29-2009 12:03 PM
piece of transmission missing, any ideas? RngRovaClassic Range Rover Classic 7 06-30-2009 11:23 PM
Transmission Question Zigidias Discovery Series II 16 03-05-2009 04:39 PM
Transmission swap? plowman Discovery Series II 1 01-23-2009 04:29 PM
transmission problems scotth Discovery Series II 1 04-20-2007 11:06 AM
