#16 (permalink) | |
Most large diesel farm machinery still uses the oil bath filter. Dust is a major problem when tractors are out busting sod, or harvesting grains. The oil in the bath traps all dust in the air, passing through the oil. The upside of modern, smaller paper elements is pretty much the inverse of the above. |
#18 (permalink) |
Terry, very well put. I like your style of debating.
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
#19 (permalink) |
I seem to have a different experience with K&N than Terry does. I was as scepticale as anyone could be till I tried one. I wanted to adapt the Oil can into a filter element type but decided it was too much effort. The air would have to go down the outside of the filter and up through the center and somewhere in there cross the membrane. Too much like work I thought. I flatly didn't beleave K&N's claim of huge power increases. Till I tried it. I always compare new mods with performance between set points on local roads. There was no noticable increase in noise (like I thought there would be) and my road speed uphill and acceleration were both increased (2.25 petrol). The true test of filter ability is the tell tale smudge inside the tubing on the 'clean air' side of the filter. No smudge with the K&N. Most paper filters will show a smudge in my experience. The original oil bath also shows a smudge. My owners manual must be different than the ones you guys have because I'm sure mine says to change the oil monthly, daily if in extreme dusty areas. Mine got changed twice a year. K&N recommend cleaning once a year for a road vehicle and the $13 kit will do the filter many times. In use, the K&N will turn from a nice red colour to brown really fast, but still gives good air flow and still show light through it. I'm impressed because it seems to do just what K&N claims it will do. If you supplement any filter with a cyclone pre-cleaner and raised intake you will get even better preformance. I wonder about the ability of the oil bath when I look at the size of the spaces between the wire mesh. The dirt has to accidently strike an oil soaked wire to get trapped. There is an awful lot of space for that dirt to get by.
Biggest down side I know of for the Oil Bath filter is the huge amount of drag when trying to start a cold motor. In cold weather with thick oil, the starter motor has to drag air to bubble through the oil to start the engine. Once things are in motion, it no longer bubbles as oil is dragged up onto the wires and the air can make a clear passage from the intake and up through the element. It is only that first bubble or two that is difficult so your pistons are trying to draw a vacuum. The one photo shows the K&N part number. It is the wrong opening diameter but a piece of exhaust pipe necked down fixes that. I installed it on the end of the original hose to make a quick return to O/B if I had to, and just incase the length of that hose is calculated into the performance figures for the motor. I don't want to loose low end torque. Greg S |
#20 (permalink) | |
Series Moderator
Cheers Onz |
#21 (permalink) |
I have a similar setup to greg s, except i (by complete luck) found a K&N filter designed for a motorcycle that has the same oval shape as the stock intake elbow. I have no complaints thus far, but i never ran the engine with the original filter, so i have nothing to compare to. If anyone is interested in the filter number i can get it and post a pic.
![]() Happy Rovering MY (SMALL) FLEET 1965 2A 88 Hardtop being restored any advice welcome PM me or something |
