Howdy all, this is my first post here, yes, I've searched, looking for a good donor vehicle to swap out my old rusted springs on my SIII diesel, the intent is to come up with a near exact fit. For both F&R from a salvage yard, I'll keep searching, in the meant time any info anyone?! I'd like a softer ride but would like to keep the height near stock, any info thanks in advance.
Just get replacement springs and keep some weight in the back to soften the ride a bit. A truly soft ride is pretty much impossible but if your leafs are rusted up solid new will improve things a good bit.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
New standard ones will make a massive difference over old rusted/tired ones.
But honestly go for parabolic springs. It's the only sensible option. There are loads of places to buy them in the UK and they will ship to the US.
Not sure if you can get them in the US. I often frequent Jeep forums and none and I mean none have heard of parabolic springs, which is stupid as they have been around since at least since the early 70's.
If you are not sure what they are I#ll post up some info for you.
__________________ Land Rover Discovery (3 Door) 200Tdi 5-speed Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights
Steve
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2, 2" lift, CDL. RTE front bumper with 9500# Ramsey winch "BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
Thanks for the reply, and the info! I'll try and reciprocate in time, I was planning on getting flamed to heck like of the pirate bb, maybe later...because the next logical question is:
I'll only be towing a jetski (50Lbs tung weight) or maybe 150 lbs of gear when I hit the trail and that's only about 5% of the time, so should I go with the lighter weight springs?
I'm not to sure but I think we call parabolic's progressive rate springs here.
Parabolic springs allow each leaf to work independantly. Thus giving a better ride, handling and articulation. But still offering as good or better load carrying and increased ride height. Essentially they will work much the same as a coil spring does.
Note the leafs don't touch each other:
What is a parabolic spring?
Basically a HST Parabolic Spring is a spring that consists of two or more leaves. The leaves touch only in the center, where they are fixed to the axle and at the outer ends, where they are fixed to the vehicle. In between those two points the leaves do not touch each other as they do with conventional leaf springs.
Each leaf represents a complete spring in it's self and will act as such. To enable this the leaf is tapered, from the center (thick) to the outer ends (thin). This tapering is parabolic, it means that every centimeter (or inch) the thickness of the leaf decreases in an amount that relates to the square function of it's length.
Conventional leaf spring:
If your existing springs are not worn, you can pull them apart and clean them up and re-use them. They wear where the end of each leaf is. That is the lower leaf wears into the upper leaf, reducing the thickness. If they are simply too stiff, leave one or two of the smaller leafs out when you reassemble them.
Parabolics give a softer ride, but make the car less stable. So it depends on what you are after.
Less stable - bollox.
They where first used on the 101 which primarily was designed for transporting ammo. Making it unstable on rough terrain would not have been a design critera.
Gee you really come out with total horse poop.
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
We have two series trucks with parabolics, a '71 S2A 88", and an 83 S3 Stage One 109 and both are not remotely unstable. I'd never go back to conventional springs because parabolics have a progressive rate increase as they are deflected, very much the same as progressive coils.
I'm not trying to stir up and trouble, just making my observations based on 2 trucks we currently have with them.(everything else has coils)
