Old 10-02-2005, 07:37 AM   #1 (permalink)
Default over heating or not?
hi ive being trying to use my 109 deasal for work a lot more its a 110 mile round trip .some time ago i replace the temp sender becos it did not seem to go up since then it gos up a bit too far ive got a kenlow type fan which when swicthed on the temp was just befor the red but no water loss all seemed ok util it lost a blade and started shakeing the motor to death so i refitted the old blade metal water pump standard fan temp still gos just b4 the red and up hill gos a bit higher but no steam or water loss any idears??
log burner is offline   Reply With Quote
Old 10-02-2005, 11:32 AM   #2 (permalink)
Series Moderator
onslow's Avatar
sounds like the thermostat has failed stick a new one in
Old 10-02-2005, 12:05 PM   #3 (permalink)
i forgot to say i looked at the themostat its not ther
Old 10-02-2005, 04:52 PM   #4 (permalink)
TerryS's Avatar
First thing I would do if an electric guage is telling you there is a potential problem, is check the temp with a probe thermometer to be certain it's actually as hot as the guage says. A bad voltage stabilizer will make your guage read high, if your guage is getting more than 10.5 volts.
Assuming there is a high temp problem, get your rad flushed, block flushed, and for heaven's sake, put a new thermostat in. Diesels need a proper, regulated operating temp
TerryS is online now   Reply With Quote
Old 10-03-2005, 01:15 AM   #5 (permalink)
hi yes it had a new rad and the themostat is on its way down i will look at the volts to night but be for i changed the temp sender it was always reading real low
