Looking into the options to get my series to go freeway speed. I am looking for the pros and cons of overdrive units and high ratio transfer boxs.
Thanks in advance.
'06 LR3 SE7 '94 D90 #115 '72 Series III 88 |
Price wise, it's a toss up. both about $1500.
Going with an OD, you still have the standard ratios and, hence, more versatility. Transfer case swap is a little (but not too much) more work, but presumably, it'll be quieter, and you don't have to chop an extra hole in your tunnel. RN claims 32% increase, and I am not sure what the Fairey increase is. I've got a Fairey OD, but think I would have rathered the Hi Ratio Transfer case. Ask Griff what he thinks of them (If he's finally gotten his truck) |
Otherwise known as STEVE
The overdrive in mine doesn't make it go any faster, it just makes it rev less at right about the same speed. The lack of torque still limits the top speed.
Thanks for the response guys. I am leaning toward the high ratio because the as you mentioned Terry, the price is the same and I will end up with a rebuilt t-case out of it. I am not overly concerned with the need to have 16 gear options, so that also points me to the high ratio. Griff did get the 109 delivered, and was thinking about bringing a few tools and doing a midnight visit.
#5 (permalink) | |
When you have wound the piss out of first, do you shift to 2nd to go faster, and likewise, 2nd to third, and so forth? So why do you not go faster in OD then fourth? HP and torque are a function of engine speed, not vehicle speed. I will grant you, these trucks have the aerodynamics of a refrigerator, but surely, if you could get it to about 3600-4K in fourth, you could pull some more revs from 2800 in OD. I can't understand why your truck won't go faster in OD then the hundreds of others out there with an OD. |
#6 (permalink) | |
#7 (permalink) | |
Okay, I am kidding and he is thrilled with it. Lucky bastard.
#9 (permalink) | |
. But seriously, no problem, we'll get yours installed. ![]()
#10 (permalink) | |
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. |
#11 (permalink) |
Personally I want the Rocky Mountain OD... it is quieter than a fairey, and it still gives you all the versitily of having low 1st/2nd. As well being able to split the gearing while going up hills is gonna be a great advantage. Alot of times in third gear I am starting to wind out the engine, yet it bogs in 4th... so being able to use 3rd plus overdrive will put me smack dab in the right gear.... with the high ratio transferbox, I would be worried that I could not get the right gearing..... but that is just me....
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
#12 (permalink) |
Seriously? Well I'll be dipped in cacalucci, cuz I sure don't have any trouble pulling 65 now, but sure struggled to see that b4 the OD. I'll have to ask George (he owns Fairey now) why he claims an increase in speed. Maybe he feels safe since his customers are too afraid to tell him differently.
So are you also suggesting that installing a high ratio xfer case will yield no more in speed? |
#13 (permalink) |
(insert popcorn icon here) this could get interesting.... where is Hank when you need him.....
#14 (permalink) |
Actually Kevin, it occured to me we're not comparing apples to apples. Steve's truck is a 109SW and if I remember, he said it was 2.25 diesel. Your's, while still an 88, looks like it's got to be a good bit heavier than mine, a soft top 88 with a fresh engine. If memory serves, a 109 is about 750 pounds more than a HT 88, take away another 200 pounds, or so for the soft top.
#15 (permalink) |
Also, Kevin, I do not think your tires help you much as well.... just a thought... (although they are great off the road.... )
I know from experience, my brothers 109 dormobile has a fairey overdrive in it.... and it definately allows him to get at least 15km/hr faster (mind you he does have the 2.5 petrol, not the 2.25 so once again not apples to apples... more like pears to apples..)
