Old 10-09-2004, 10:24 AM   #1 (permalink)
Unhappy Which parabolics?
I need to replace the springs on my '71 109" SW.
As there are several options, do any of you have strong feelings or past history? It seems like the options are: Rocky Mtn (Wise Owl), Santana, or British Spring (from Rovers North).
Also, the springs on the front are fairly new- while the rear springs are shot. Is there a problem with replace only the rears with para's (front being semi-elleptical)?
What are the performance differences between OME, genuine, and Pro Comp shocks.
Thanks.
1971 SIIA 109" SW RHD
1995 RRC LWB
Jared is offline   Reply With Quote
Old 10-12-2004, 09:12 AM   #2 (permalink)
Snagger's Avatar
TICs are very good, but also very expensive. Popular consensus is that RM are the best value.
It's not broken; it's British
Snagger is offline   Reply With Quote
Old 10-12-2004, 09:36 PM   #3 (permalink)
[quote=Jared]I need to replace the springs on my '71 109" SW.
They say to replace the whole set at once but I did the front two and the rear several months later. I didn't notice any problems but still I would recommend you do all at the same time. I run on RM and like them.
Greg S
1970 109 SW LHD
Greg S is offline   Reply With Quote
Old 10-13-2004, 11:20 AM   #4 (permalink)
Snagger's Avatar
No problem replacing in pairs rather than in fours, though you won't see the full benefit until you do them all (including suitable dampers).
Old 10-13-2004, 04:36 PM   #5 (permalink)
Default Shocks
Thanks for the feedback.
I still need some opinions on the different shock options I have- stock, OME, etc.
My driving is 80% road- with the 20% off-road being a sampling of Colorado's tougher trails.
Thanks!
1995 RRC LWB
Old 10-13-2004, 10:58 PM   #6 (permalink)
V8_Agro's Avatar
If you are to fit para's to your landy you need to fit a long travel shock so you get the most out of your springs in travel distance when offroading.
Most long travel shocks are a firm ride unless you get the adjustable type like Rancho's, Tough dog etc. In my experience I would stick to a well known shock that suits the landy like OME, Bilsterin Koni etc they are all good quaility .
I have fitted all these in the past and found them all to good
Adam
undefined
Oh behave
99 Defender 130 C/C
98 V8 Disco RIP
93 V8 Disco RIP
80 V8 Stage 1 RIP
V8_Agro is offline   Reply With Quote
