Hey guys,
I'm working on my 71 Series IIA right now. I just removed my fuel sediment bowl, cleaned it, as well as resealing my tank and painting it. Now everything is back and place and I'm trying to prime my fuel lines. I assumed to do this just by pumping the little lever on the fuel pump, but a couple hundred pumps in without results, and I'm having some doubts. Is this the way to do it, or am I going in the wrong direction? Thanks
. Brandon ------------------ 1971 Series IIA 2001 Discovery |
jimfoo
That's the way to do it, but maybe the bowl isn't sealing. You can also help it out by sucking on the fuel line while pumping it, keeping an eye on the bowl so as not to suck gas. Or the lazy man's way of buying a low pressure electric pump and putting it inline with or bypassing the stock pump. But if you have a Weber, then a fuel pressure regulator is needed.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
I'll probably try sucking on the line tomorrow. There did seem to be a seal on the bowl though, as there was definitely an increased resistance on the lever compared to when I broke the seal.
I'll report back tomorrow and let ya know what happens. BTW it's a Zenith
There is either a rubber or paper gasket that goes between the bowl and the pump. Make sure that you did not lose or tear it. If there is a tear or it is missing, then you get an air leak and no pressure. I also find sometimes it helps to fill the bowl with gas (seems to help for me, not sure why...)
The easiest way is to dump a small amount of fuel down the carb and start the engine, adding the fuel again before it dies. Let the engine do the pumping and save your hands for something more useful... ![]()
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
You can test it by removing the inlet line and holding your finger over the port while working the lever. You should feel suction on your finger.
You can do the outlet port the same way and see if you feel pressure. If you ever have the problem again. You pump may be weak, I've never had to suck on the line unless the pump was faulty.
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
| Thread Tools | |
| Display Modes | |
| 2.25 diesel engine fuel priming after line replacement | archaeology_student | Series Land Rovers | 4 | 02-13-2008 12:49 PM |
| [D2] Service Intervals | rmuller | Tech & DIY | 1 | 05-10-2007 09:11 PM |
| Fuel lines need replacing | Kevin88RRC | Range Rover Classic | 5 | 10-19-2006 02:19 PM |
| HELP!! Fuel Pump??? Truck still on trail. | bluemax09 | Discovery Series I | 14 | 02-22-2006 03:40 PM |
| What should I have done during maintenance? | appstatedisco | Discovery Series I | 2 | 09-12-2005 07:57 PM |
