Old 05-11-2008, 06:43 PM   #151 (permalink)
01001010's Avatar
Gallery: 15
Work continued today with cleaning and installing the push rods. After cranking it a few times it just wouldnt go...so I decided to remove the head and see just what was going on in there.
I found the following...
  • Several of the head bolts were way under-spec and came off quite easy
  • The fowardmost tappet assembly is damaged
  • The block desperately needs a flush
  • The distributor pump is loose
On the plus side,
The cylinder walls look fantastic and the head is in great shape.
Since I'm going to have to get in there, I've decided to just do an engine overhaul. Might as well rebuild it while im in there. But that will be happening at a much later time. As of now, engine work is done and I will continue to move foward and finish removing everything from the frame.
JC...
1965 Series IIa 109 RHD Dsl - Wilks
www.TerraTrekker.com
Old 05-13-2008, 08:46 PM   #152 (permalink)
01001010's Avatar
Gallery: 15
Well, im waiting on a few new cubbies I ordered to keep things organized. In the meantime, I think im going to begin restoring the windshield frame which has some corrosion on the surface.
I've read that wire wool may do more damage than good. I've also read of people using scotch bright pads...but the pads alone? Any liquids?
JC...
Old 05-13-2008, 09:25 PM   #153 (permalink)
AAXD's Avatar
Gallery: 1
The green pads alone should remove any rust from the galvanising, assuming there is some zinc left underneath. Thats how I got rid of the rust on mine. The zinc will grow a new "film" with time that will protect it from any further corrision. Just don't be too aggressive with it or you'll start to strip it off.
Colin's Toys:
1972 Series III 88"
1997 Discovery XD
1983 Stage 1 109"
2002 Trek 4500
2005 Necky Looksha Sport
2007 Rans Rocket
2007 Honda Ruckus
Wounded Warrior Project Bwana The Lounge 3 01-19-2008 11:37 AM
LRS New Parts & Take Off Parts & Project Trucks Dominic Land Rover Parts and Accessories 1 09-25-2007 08:20 AM
Update to our project (or at least a bit of reading) Rhich Discovery Series I 3 03-16-2006 03:52 AM
Disco/Defender Hybrid Project RedRhinoProducts Land Rover Vehicles 0 12-11-2005 11:20 AM
1966 109" project for sale Bogatyr Land Rover Vehicles 1 10-11-2005 01:56 PM
