Old 10-05-2004, 02:49 AM   #1 (permalink)
Default rover donk ULP
Hi.
I am hoping that someone can answer a question for me.
I have been told by a service station owner that I can run my series IIA 2 1/4 litre donk on straight ULP (without fuel additive). He further went on to say that ULP was once known as "Standard" petrol. Don't know if he's pulling my leg. Hoping someone out there in Rover Land can answer this puzzle for me.
rover mad.
rovermad is offline   Reply With Quote
Old 10-05-2004, 01:34 PM   #2 (permalink)
Lawnmower's Avatar
I think all leaded petrol engines will run on unleaded petrol.
Lead in petrol acts as an 'antiknocking agent', and it is this that can be added to unleaded as a lead replacement additive.
Landrover engines are pretty tough, so the increased wear and tear on the engine from not having lead will be minimal. youcan buy replacement cylinder heads (i thinks this is what needs to be changed) to convert to unleaded, although it may be worth while just waiting till your present one deteriorates to the point it needs changing.
have yo considered LPG as an alternative?
Lawnmower is offline   Reply With Quote
Old 10-05-2004, 01:57 PM   #3 (permalink)
Many thanks for your input Lawnmower.
I have recently reconditioned my donk to new condition- new everything that can be fitted including the head. Your suggestion of LPG sound like a very good alternative.
Cheers!
Old 10-06-2004, 02:11 PM   #4 (permalink)
Generally when older engines are run on unleaded the main cause of concern is valve seat recession. This is where the valve seat in the head slowly wears away and the valve recedes into the head. Rather than buying a new head, you can get your local engine reconditioner to fit seat inserts. These are hardened and solve the problem. Adjusting the timing is the other thing tro look at if it pings. Doesn't hurt to run an additive as well. I don't know what you have available in England as far as fuel catalysts. Here in Aussie we have what is called a Prozone. it fits in your fuel line like an inline filter and replaces the lead basically with trace elements and it works exceptionally well. I have a 1970 Ford ute with a highly modified 302 (5.0 litre) v8 ( i know it not a landrover but it is a good example of what a Prozone can do )that i run on unleaded with a Prozone. it improved performance and economy. They work equally as well on non modified engines as well. Email me if you want some info.
Rovers Go Bush
Pete
Defender Man is offline   Reply With Quote
Old 10-06-2004, 02:45 PM   #5 (permalink)
it will run fine on it m8
mathew is offline   Reply With Quote
Old 10-06-2004, 08:58 PM   #6 (permalink)
Thanks Pete.
A.J.
Old 10-06-2004, 08:58 PM   #7 (permalink)
Thanks Matthew.
A.J.
Old 10-07-2004, 01:31 AM   #8 (permalink)
No worries A.J. Drop into your local Repco. They sell the Prozones. They will have info on them. I bought mine through them. or check them out here
Prozone
