» Sponsors
» Sponsors
Old 09-18-2009, 04:41 PM   #1 (permalink)
Default Screw On Wheel Studs
I have a 65 IIa w/screw in lug studs. The holes are stripped on a couple of them. Does any one have a sugestion for repair?
Can the holes be drilled andreplace screw ins w/ press fit studs?
Tom Shepherd is offline   Reply With Quote
Old 09-18-2009, 06:53 PM   #2 (permalink)
antichrist's Avatar
I'm pretty sure the later splined studs will press in to the existing holes.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 09-21-2009, 09:45 AM   #3 (permalink)
The later splined studs will press in but are too short because of the top hat section. They can be made to fit quite easily be making a counter bore in the back side of the hub. IIRC the top hat section on the later stud even has a tapered face on it so a standard drill bit does for making the counterbore.
On my hubs with screw in studs I put a tack weld on the rear face to stop them spinning.
greenmeanie is offline   Reply With Quote
18X9 Wheels on my 2inch lift 95 classic tebelleh1 Range Rover Classic 9 04-23-2008 11:06 AM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 07:33 PM
Heater, coolant leak question for 2000 P38 Dburgoyne Range Rover P38, Mk III and Range Rover Sport 8 02-23-2007 02:47 PM
Series II Wheel studs thread NumbNuts Series Land Rovers 8 01-11-2005 02:37 AM
