Old 01-04-2007, 09:56 PM   #1 (permalink)
Nilhan WeeraSinha's Avatar
Default Series 3 1982 Tie Rod Ends
The off side tie rod end worked itself loose and came undone during a jungle safari in Sri Lanka just before Christmas.
This appears to be a frequent problem with off roading Land Rovers. and the remedy in Sri Lanka is to spot weld the Tie rod end to the tube on the off side.
What do you recomend?
Regards
Nilhan
Nilhan WeeraSinha is offline   Reply With Quote
Old 01-05-2007, 05:24 AM   #2 (permalink)
pickuprover's Avatar
I've never heard of a tierod coming undone... as for spot welding it on, that might be a cure, but I would not want to be the one to have to take it off, or to adjust the alignment. Usually the problem is getting them loose in the first place when you need to change them. I think if it is a common problem in your area, that I might be using th torque wrench on it whenever I do my oil change..... just a thought..
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 01-05-2007, 06:35 AM   #3 (permalink)
antichrist's Avatar
Never heard of this before. Never had it happen, even on my Series that was use 100% off-road 5 days a week.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
