Old 10-17-2004, 01:37 AM   #1 (permalink)
g7jtk's Avatar
Default Series 3 clutch
The clutch doesn't work on my lightweight. There is no resistance at the pedaland has lost fluid, I have refilled with fluid and everthing seemed ok but when I went touse it yesterday no clutch or fluid. Obviously there is a leak. The question is where is the leak likley to be? There are no extra drops underneath and it is raining hard so nothing would show anyway.
g7jtk is offline   Reply With Quote
Old 10-17-2004, 01:52 PM   #2 (permalink)
Snagger's Avatar
Master cylinder leaks tend to make themselves known with fluid dribbling down the pedal onto the floor. A slave cylinder leak will have dumped fluid into the bell housing, and having lost 2 systems' worth, you may have an indication from the bell housing drain hole. A leak from the pipe work may show itself by degreasing (and eventually paint stripping) an adjacent patch of the bulkhead.
It's not broken; it's British
Snagger is offline   Reply With Quote
Old 10-23-2004, 08:58 AM   #3 (permalink)
g7jtk's Avatar
New slave unit fitted and fresh fluid so we are on the road again.
