Old 06-30-2006, 04:38 PM   #1 (permalink)
Default Series 3 clutch master cyl replacement
Is it true the left fender must come off? This is a 1973 NAS 88 version. I've read fender must come off and heard it doesn't. Anyone done this?
Thanks,
Doug
smackeyboy is offline   Reply With Quote
Old 06-30-2006, 06:53 PM   #2 (permalink)
pickuprover's Avatar
Thanks,
Doug
I believe it does (I know the danish spec 109 does..) but since the fenders are so eay to take off why would you not?
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 06-30-2006, 07:38 PM   #3 (permalink)
Default Fender removal
Very new to Series ownership. How easy is it to remove the fender? If it's that easy I'm up for doing the master, slave and the flex line. Let's get it all done in one shot..... All parts are on hand.
Thanks again,
Doug
Old 06-30-2006, 08:03 PM   #4 (permalink)
TerryS's Avatar
There are two ways to change (or remove/rebuild/replace) the clutch master in a LHD rover. Actually three if you consider that many, too lacking in good skills, chopped a piece out of the back edge of the fender. My first 88 had a beutifully installed piano hinged piece. So much energy but not real smart.
The first method is to just unbolt the fender. There are four bolts holding it to the bulkhead, a couple holding the inner skirt to the frame, then the few holding the front inside edge to the breakfast panel.
The second method, a little less time consuming, is to unbolt the bolts which hold the pedal box to the bulkeand. I think there are 6 3/8". Then you can tilt the pedal box on an angle to get the two bolts holding the MC to the pedal box, and unscrew the plunger shaft from the cross pin on the pedal.
I've done it both ways. Neither is easier than the other. The reason I got to doing it without removing the fender, is that I also have a Defender 110, and removing their front fenders is a major pain, what with the roll cage and inner cage supports.
Old 07-01-2006, 04:18 AM   #5 (permalink)
Unbolt the brake master cylinder from the vacuum assist and pull gently out of the way.Remove the vacuum assist separtely and then the brake pedal housing.This makes a lot of room to get the clutch m/c out.
s3landy is offline   Reply With Quote
Old 07-07-2006, 03:05 PM   #6 (permalink)
Well, thats what you get for driving on the wrong side of the road
Buckle
`66 Light Weight
Buckle is offline   Reply With Quote
