» Sponsors
» Sponsors
Old 08-12-2009, 03:29 AM   #1 (permalink)
Mark1987
Default series 3 facelift
hey hope someone can help im looking into getting a series 3 and going hole hog of sorting it out just wondering if there is a facelift kit to make a series 3 into a defender just from the front though this forum has been great help from deciding what to get and what to do to it if a kit exists could someone let me know where i can get hold of it by posting sellers website thanks. mark
mark1987 is offline   Reply With Quote
Old 08-12-2009, 05:24 AM   #2 (permalink)
TerryS's Avatar
Rovers North has used bonnets (hinges are same as S3). Then all you'll need are the headlight facias, correct parking lights and signals, a radiator panel, Defender radiator top support panel (holds the bonnet latch) and grill. I've never seen a "kit".
Personally, both trucks have their own character, but making a series truck look like a Defender either says you've fitted a different engine and needed the length, or it looks like a wannabe.
Old 08-12-2009, 05:25 AM   #3 (permalink)
pickuprover's Avatar
Not sure why you would want to make a Series III look like a defender. Why not get a defender and have the advantages of the coil springs, stronger engine and such...... I do not know of any kits, but it is not too hard to pull a front end off a defender and put it on a series.
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 08-29-2009, 06:11 PM   #4 (permalink)
Mark1987
yeh it is for the new engine 2.8 fourtrak diesel v8 so i need the room really unless you have an idea of what reliable engines will drop in the gap got to be diesel with ok mpg
Old 08-31-2009, 09:08 AM   #5 (permalink)
From your other posts it seems you want to have a tax exempt truck that is extensively modified. Before going too far you should investigate the points system and the SVA to determine whether your intended result will still qualify for tax exemption.
If you want to go diesel the well documented and comparitively cheap route in the UK is to use a 200Tdi. Google is your friend here.
greenmeanie is offline   Reply With Quote
Old 08-31-2009, 10:17 AM   #6 (permalink)
gordo's Avatar
Its easy to put a D90 front on a series. The fenders work fine, you just need a D90 hood and breakfast plate, grill. I did that to my hybrid below in the photo. I had to make room for the v8 as I put the series body on a RRC frame. I personally prefer the look of the series recessed breakfast but it was easier to move the grill out than push the drivetrain all back. Gordo
Gordo
www.floridalandroverclub.com
00 P38 4.6 blinging
92 stocker RRC
73 hybrid wheeler
gordo is offline   Reply With Quote
Old 09-02-2009, 10:03 AM   #7 (permalink)
Mark1987
yeh thats my issue will be doing an engine conversion on mine in process of looking at getting one looking around trying to find a diesel one already done but if not will be doing it myself
Dude Where Is My Series Rugbier The Lounge 3 06-15-2009 11:39 AM
Series 1 Land Rover with a Twist roverso Land Rover Vehicles 4 03-15-2009 11:51 PM
I am pounding the crap out of that thing zed Series Land Rovers 19 04-29-2008 01:00 AM
engine ID zed Series Land Rovers 0 04-27-2008 02:37 AM
muffler AdrianL Range Rover Classic 14 03-23-2005 10:08 AM
