Old 03-05-2008, 10:29 PM   #1 (permalink)
dsfloyd's Avatar
Question Series II wheels
I am new to this post and looked for a little while to find an answer before asking the question but here goes. I currently have 27x8.5/14 on my '60 series II. I want to go back to a 15 or 16 inch wheel and I want to run a 31-33 inch tire, maybe 34 if they won't kill it (I think about 32 or 33 was stock 9.00x16). I was looking at LTB's or TSL's which typically run 10.5-11.5 wide. My Series is not a daily driver so I want very aggressive tires. So here is my question. For the larger wheels am I restricted to a stock rim which usually is 5.5-6.5 wide (have found one that is 7), or are there other aftermarket wheels? I think for the tires above a minimum of 8 inches wide is required. I am assuming the bolt pattern is "unique" and so it will be hard to find an aftermarket wheel. What size tire do other series owners run on their wheels if they are the smaller width?
Thanx
'60 Series II 88
'04 Silverado 2500 4x4
'02 Altima 2.5 (Hurts less at the pump)
dsfloyd is offline   Reply With Quote
Old 03-05-2008, 10:55 PM   #2 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
I think the most common large tire is 235-85-16 which is about the same as a 7.5x16. The 9x16 was on FC's. Very tall or wide tires will screw up your turning radius unless you space your wheels out or find some with a lower offset. Wider ones will still probably rub on the wheel wells unless you cut them, as will very tall tires. Land Rover Steel Wheels and OFF ROAD OFFROADERS OFFROAD WHEELS MOTORSPOTRTS Buy MRW are a couple places that sell wheels.
Jim Hall
obstacle.” Michael
Old 03-06-2008, 08:59 AM   #3 (permalink)
dsfloyd's Avatar
Thanks for the info.
'60 Series II 88
Old 06-01-2008, 12:09 AM   #4 (permalink)
Unlicky 13
unlicky13's Avatar
Gallery: 3
Question wahoo im looking for old school rims will trade
i have a 63 landrover with off road rims but im looking for the plain steel rims 16? the wheels that are on it now are big also what other wheels will fit from other cars does n e one know what the bolt pattern is n e help i can get is better then none does n e one know where i can get used parts cheap or is there a junk yard in ny ?
unlicky13 is offline   Reply With Quote
Old 06-01-2008, 08:06 AM   #5 (permalink)
Rebuilding Rover
ArmyRover's Avatar
the disco I steel wheels should fit no problem on it
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 06-01-2008, 10:52 AM   #6 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
seen disco wheels on rr and series and hybrids..
looks like the offset is a bit more positive. Seem to be in the wheel arch vs tucked away.
like my factory 7.5"(?) steel with 285s
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Old 06-01-2008, 03:20 PM   #7 (permalink)
antichrist's Avatar
Interesting, in my 34 years of being around rovers I've never seen a 14" wheel on a Land Rover.
On most of my series Rovers I've always run 7.50x16's (32" dia). My '62 has 7.00x15's (about 29" dia or so). On a '74 I used to own I ran something like a 30x10.5x15 (something like that, it's been 30 years ago so I can't remember for sure).
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 06-02-2008, 12:06 AM   #8 (permalink)
Unlicky 13
unlicky13's Avatar
Gallery: 3
Default bolt pattern
so whats the bolt pattern? for a 63 landrover wagon
Old 06-02-2008, 06:21 AM   #9 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Land Rover has a bolt pattern unto itself as far as the US is concerned, so you won't find wheels from some other make. 5 x 6.5
Jim Hall
obstacle.” Michael
Old 06-02-2008, 09:33 AM   #10 (permalink)
dsfloyd's Avatar
Antichrist
here you go
My grandfather put them on a long time ago maybe to gear it down lower as he did a lot of hunting, but not sure they've been on longer than I've been alive
Other pics are in the show it off section.
'60 Series II 88
Old 06-02-2008, 09:48 AM   #11 (permalink)
Rebuilding Rover
ArmyRover's Avatar
learn something new everyday when it comes to Rovers lol
90 RRC Parts truck
Old 06-02-2008, 09:51 PM   #12 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Not a factory wheel. They look custom to me.
Jim Hall
obstacle.” Michael
Old 06-03-2008, 09:39 PM   #13 (permalink)
Unlicky 13
unlicky13's Avatar
Gallery: 3
is n e one getting rid of the 16 inch stock basic rims ill trade them mine looking for 5 or is n e one selling them cheap near ny ?
Old 06-05-2008, 09:09 AM   #14 (permalink)
32" or 7.50X16 is about as big as you want to go on a stock landy. Bigger and you'll raise the gearing too high for the 4 pot and you'll also start eating those 10 spline rear axles.
You can sort the axle thing but power is always an issue.
Cheers
Gregor
greenmeanie is offline   Reply With Quote
FS 18" wheels Discovery Series II + Range Rover krigsmakten Land Rover Parts and Accessories 0 09-21-2007 07:12 PM
5 Land Rover Discover series 2 wheels $200 DoubleD123 Land Rover Parts and Accessories 1 09-04-2007 06:59 AM
16" wheels for a Series I to III Rat Patrol Land Rover Parts and Vehicles Wanted 9 04-01-2007 06:30 PM
Range Rover wheels on a series 1 Disco? ozmoto Discovery Series I 7 06-21-2006 09:58 PM
Range Rover/Disco II 18" Mondial Wheels K Kelly Land Rover Parts and Accessories 1 01-07-2005 08:56 AM
