Old 07-27-2005, 04:29 AM   #1 (permalink)
Unhappy Series III - Gearbox Problems
Hi I'm a newbie here and to landies,
Just bought a SIII 88" Hard Top, and seem to be having problems with 1st and 2nd, as they crunch as I select then, is this to do with the clutch or the syncromesh. Please help me!
Oh its a 1973 if that helps!
Drewid is offline   Reply With Quote
Old 07-27-2005, 06:36 AM   #2 (permalink)
Bogatyr's Avatar
Drewid,
Yeah, I'd think the synchros would be on the way out if the clutch is adjusted properly. Just to verify, try double clutching and see if things quiet down...if so, it's the synchros.
Bogatyr
Current Rover Fleet:
Old 07-27-2005, 08:21 AM   #3 (permalink)
Cool
Thanks Matey, I will try it, can the syncros be fixed, or is ir a new gearbox???
Old 08-02-2005, 06:07 AM   #4 (permalink)
Arrow
Or it maybe that you have a series 2 box - they don't have synchromesh on 1st and 2nd gears!
Buckle
`66 Light Weight
Buckle is offline   Reply With Quote
Old 10-14-2005, 07:05 AM   #5 (permalink)
have you checked that you have a full clutch fluid reservior?
adscan is offline   Reply With Quote
Old 10-17-2005, 12:04 AM   #6 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
Also check you oil levels in your G box - Not just the transfer case!
Moeras
’74 SIII 88” 345 000 Miles & still going strong!
Reality - an illusion caused by the lack of alcohol in the blood.
Moeras is offline   Reply With Quote
Old 10-18-2005, 03:26 PM   #7 (permalink)
Series Moderator
onslow's Avatar
If it only first and second check firstly its not a s2 box as has been mentioned,if it is a 3 box then its the syncro hub which is shared between 1st and 2nd they can be replaced no problem and are readily available
