Hi,
I have noticed that my speedo needle tends to bounce around quite a bit. Is there anything I can do to correct this little annoyance? I just thought that I would ask. I have not had a chance to get into my instrument panel... does anyone know what type of light bulbs are inside that illuminate the dash? Are they wedge based, or the bayonet style? Thank you ![]()
"The use of vegetable oils for engine fuels may seem insignificant today. But such oils may become in course of time as important as petroleum of the present time." - Dr. Rudolf Diesel, 1912 MSN Blog with LR info and Photos |
Usually the speedo wobble is because your output bearing on your tranny is loose... but this is a fairly major job to fix.. try the oil first... but check to make sure you have no play in the rear drive shaft.... (make sure you check without the emerg brake on....)
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
