hi again
any no of any one out ther thats fitted a sherpa 2.5 lump ive heard thay are a stright fit can any body give me some info on mpg on a run and do thay pull any better the the old 2 1/4 D |
The Sherpa engine (which is a '14J' engine) is the same as the 2.5 N/A diesel in the Landy 90 and 110 (these engines are called the '12J'). The only difference is that the Land Rover version has a cast timing belt cover that can be sealed simply by fitting the wading plug. The Sherpa engine has a lightweight aluminium (I think) casing, which is not waterproof, so if you plan on going wading, get it sealed.
They are a straight swap from a 2.25 diesel (which for the record, is the '10J' ). You need to keep the engine mounts from the 2.25 motor, plus its clutch system and fuel filter/spill return system. You'll also need the thermostat housing off a 2.25 so you the 2.5 engine will fit a Series radiator. You'll also need to make up some form of cable throttle control, since the injector pump is in a different place on the 2.5 compared to the 2.25. To keep it easy, use the intake/exhaust manifolds off the 2.25 as well and use the standard oil-bath air filter system. Someone I know who used to have a Ninety with a 2.5 N/A got around 28-30 MPG, that was with a 5-speed gearbox. Having said that, my 2.25 does the same with a 4-speed. There wasn't much difference is acceleration or top speed (the 2.5 only has 6 more horsepower than the old 2.25), but it was noticeably better at climbing hills. It was still pretty slow, but you could hold 4th gear slightly longer, and when towing it seemed to have a little more 'oomph'. If you want the figures: 2.25 N/AD = 62 hrsp @4200 rpm, 103 lb-ft @ 1800 rpm 2.5 N/AD = 68 hrsp @ 4200 rpm, 114 lb-ft @ 1800 rpm
1990 Ninety County Station Wagon Diesel Turbo http://members.lycos.co.uk/threelandrovers |
#3 (permalink) | |
Series Moderator
In this day and age I would be looking at a 2.5 petrol or V8 on LPG cost per mile no diesel will beat them a 2.5 diesel will manage a sluggish 28mpg max at 90p a litre,where as a V8 in a series will show a spritely 15-16mpg on LPG at 38p a litre. cheers ONz |
Hi All,
If you want some pics of a 2.5 Sherpa motor installation let me know - I have one in my Lightweight. Would pretty much go along with everything said above though! Buckle
Buckle `66 Light Weight
#6 (permalink) | |
Jack
Just thought I'd offer my opinion from experience:
If its a short wheel base you have, then deffinately go for the Perkins Prima. It will do high 30s to the gallon, revs higher than the standard landrover units (including the 2.25 petrol), it has instant starting regardless of the weather, they are good for well over 200,000 miles and can be easily tweaked to produce over 100BHP. Just tweak the pump and add a decent intercooler similar to the one on the MG Montego Turbo. The reason I know this: I have a Montego DLX that has done 220,000 miles and is still going strong. Midrange acceleration is very good and it will do up to 60MPG in the car. I have also driven an 88" fitted with this engine and it was nothing short of brilliant. You have to give it few revs to get the turbo spining but once you get going they really fly. Not sure it would work in a 109" though. the extra weight might slow down acceleration too much before the turbo spins up properly giving a longer turbo lag. As for the Transit engine, this is the conversion of choice for me in my own 109". I only get about 18-20MPG out of my 6 cylinder and thats no longer funny. Think about it: A fully laden Transit weighs considerably more than a Landrover but will still (eventually) top 70mph. How many of you out there have driven a Transit from one end of the country to the other absolutely flat stick at 70+ without it breaking? Reliability is a forgone conclusion. Spares are dead cheap and a complete running Transit can be bought for a couple of hundred quid. The only downside I can see is that the Di engine is abit noisy. But what the hell-its a Series-Itsalways going to be noisy! |
so ok a di transit looks good for a swap any body no whats needed to do the job ie what parts and what mods to be done.................. i like my 109 the style and the way it looks but the engine is letting me down this looks like the only way to save her
and as for the noise well thats all part of it along with all the rattles shakes groans whines ect ect bit like my other hafe lol![]() |
#9 (permalink) |
Try these people for the Transit conversion:
www.engineconversions.co.uk/landrover.html or www.mdengineering.co.uk Very helpful. Not sure why there is such a proce difference though. |
#10 (permalink) |
Try www.dudleigh.com for the Perkins Prima conversion, as well...
