Old 01-10-2008, 02:09 AM   #1 (permalink)
01001010's Avatar
Gallery: 15
Default SIIa/III Gearbox
I've only done minor research on this topic and for the sake of bringing some tech into the board, I'll go ahead and ask...
Can I stuff SIII gearbox internals into a SIIa housing?
I've been doing some lookin around and while I still havent made any phone calls yet, I cant seem to find price for a WHOLE gearbox assembly from British Pacific and Wise Owl.
So far, Atlantic British has the lowest price on a SIII gearbox w/o the TC but if there's the possibility of just switchin out Gears 1 & 2 to sync gears, that'd be great!
JC...
Old 01-10-2008, 03:11 AM   #2 (permalink)
Back in a Series LR after 25 years :-)
slouzon's Avatar
Not as simple as changing out 2 gears.
The layshaft is different and I believe the main shaft and well as the reverse gear.
I switched my IIa over to full synchro but retained my IIa bell housing.
Not a bad job.
I bought a Series III box for my parts.
I took some pictures as I took stuff apart and of course while it was apart replaced all the bearings and bushings. My synchros were in good shape.
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
slouzon is offline   Reply With Quote
Old 01-10-2008, 03:53 AM   #3 (permalink)
TerryS's Avatar
The short answer is no.
The long answer is no, and why would you want to?
The 2A box is more robust, so learn to double clutch.
Old 01-10-2008, 06:14 AM   #4 (permalink)
KevinNY's Avatar
Of course if you put a Series III gearbox in front of a IIA transfer case you get the lowest series gear combinations. Your 1st lo goes from 40:1 to 50:1. While it is fashionable to say a IIA gearbox is stronger in theory, I have a run a III gearbox with 80K on it with 34" swampers, lockers, and a 9:1 ACR power plus motor. A friend runs the same box with portal axles and a 3.5 carbed V8. As long as you are not a ham fisted shifter you will be fine.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is offline   Reply With Quote
Old 01-10-2008, 06:45 AM   #5 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Never knew that about the III boxes. Good info to know. I see reverse is lower as well though it needs to be a suffix A or B transfer case or low range gears as C and later had a different ratio.
Jim Hall
obstacle.” Michael
Old 01-10-2008, 07:54 AM   #6 (permalink)
KevinNY's Avatar
Series III has a lower 1st and reverse and IIa transfer cases have the 2.88 lo range vs. 2.35 for the III. Now if someone would just invent an under/overdrive transfer case.
Old 01-10-2008, 08:22 AM   #7 (permalink)
slouzon's Avatar
I've had them both apart on my bench and other than the synchros it's pretty much the same, except the one piece layshaft.
So if you wear out the synchros you now have a IIa box!
71 Series IIa 88
01 D2
Old 01-10-2008, 11:36 AM   #8 (permalink)
antichrist's Avatar
You mean like Ashcroft?
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 01-10-2008, 01:38 PM   #9 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Only suffix A and B have 2.89:1. The C and onwards have 2.35 just like the III. I have a suffix C xfer and had to put B low range gears in it to lower my low range.
Jim Hall
obstacle.” Michael
Old 01-10-2008, 01:46 PM   #10 (permalink)
KevinNY's Avatar
Nope, the Ashcroft kit just raises Hi range but unfortunately comes with the 2.35:1 lo ratio.
Old 01-10-2008, 03:19 PM   #11 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
And I hear you can't use the B gears with the Ashcroft. Another reason why an OD is better.
Jim Hall
obstacle.” Michael
Old 01-10-2008, 03:35 PM   #12 (permalink)
01001010's Avatar
Gallery: 15
Ok, so I'm going to give the double-clutchin a go. I know I'll get it eventually. Will keep everyone updated in the project Wilks thread.
But...
Say I get tired of double cluthin or w/e... Does a SIII gearbox bolt right up?
JC...
Old 01-10-2008, 04:00 PM   #13 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Clutch slave is on the opposite side but it will bolt up though you may have to cut off a reinforcement on the frame if yours has one as it will be in the way of the slave.
This is with my VW engine and adapter, but shows where it will hit on the drivers(USA) side.
Jim Hall
obstacle.” Michael
Old 01-10-2008, 04:12 PM   #14 (permalink)
01001010's Avatar
Gallery: 15
Hmmm...I wonder if the RHDers have that same support bracket. Anyway, I was just YouTubing Double Clutch videos and I'm just making a big fuss...I'll get it.
It's good to know that if I DID want to bolt one up, that it could.
Thanks Guys! This is only the beginning of a TON of questions. Your help is ALWAYS appreciated!
JC...
Old 01-10-2008, 04:28 PM   #15 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
I usually start in 2nd anyway, so only have to double clutch to downshift.
Jim Hall
obstacle.” Michael
SII to SIII gearbox? rupertmja Series Land Rovers 7 07-28-2007 06:41 PM
SIII Gearbox for sale (Seattle) loment11 Land Rover Parts and Accessories 0 12-21-2005 05:00 PM
Synthetic gearbox oil fish Accessories 22 10-14-2005 08:34 AM
LR 90 LT77 gearbox oil improvements Timil Defender 2 05-04-2005 11:35 AM
Discovery auto gearbox problem Archy Discovery Series I 9 09-27-2004 03:54 PM
