» Sponsors
» Sponsors
Old 05-29-2009, 06:51 AM   #1 (permalink)
Default slow rover
Greetings,
I have just aquired a 1970 rover diesel runs great, however I cant get it to go over about 35/40mph. Am I missing something or is this as fast as it will go. Is there anything I can do to get it up to hwy speed?
Thanks for any help or suggestion!
JOHNIV is offline   Reply With Quote
Old 05-29-2009, 08:57 AM   #2 (permalink)
Bmohan's Avatar
Avoid headwinds?
'04 Disco SE
'72 SIII 88
Bmohan is offline   Reply With Quote
Old 05-29-2009, 09:34 AM   #3 (permalink)
LROffroad.com
Dantelaterra's Avatar
Gallery: 5
I know they're slower, but that sounds wrong... What seems to be the hold up? R u using all the gears? Is it redlining the rpm's at 35-40 mph.... Tell us more
www.LROffroad.com
"The place for Off-road Land Rover Enthusiasts"
Dantelaterra is online now   Reply With Quote
Old 05-29-2009, 09:40 AM   #4 (permalink)
Default slow rover
Greetings,
I think I am using all the gears(4) in high range. It feels like I run out of gears about 40mph with the rpms really high. If I put everything in low it has an incredible crawl. Im new to these contraptions and would like to be able to drive it often. thanks for the reply!
john Iv
Old 05-29-2009, 10:22 AM   #5 (permalink)
SeattleRRC's Avatar
Gallery: 39
Sounds like you're in low range
'75 Series III 88" 63K mi
'90 RRC SWB 232K mi
SeattleRRC is offline   Reply With Quote
Old 05-29-2009, 02:11 PM   #6 (permalink)
Default slow rover
i just checked to make sure the rover was in high range, What about this fairy od can it be installed on my rover, would it help? .
Thanks
Old 05-29-2009, 03:14 PM   #7 (permalink)
SeattleRRC's Avatar
Gallery: 39
Well mine tops out at about 50mph - but 35/40 sounds really slow.
Are you maxing out the revs? I was timid in the early days of ownership, but now I rev it up and it makes decent speed. Is the engine in tune?
'90 RRC SWB 232K mi
Old 05-29-2009, 04:45 PM   #8 (permalink)
Smokey Mountain Man's Avatar
Is that up hill or down? I have diesels and they are a lot slower than gas rigs. An overdrive will help your situation emencely. As will a turbo charger. Send me your email address and I will send you pictures of my turbo setup. And if your interested I have a faery overdrive that is for sale.
Smokey Mountain Man is offline   Reply With Quote
Old 05-29-2009, 07:36 PM   #9 (permalink)
Greetings,
I might be a little cautious on the throttle but I gave it a good run a few minute ago and I might have hit 45mph, but it was revving hard. The diesel engine seems to be in tune it doesnt smoke at all and starts right up without much of a preheat cycle. I wonder if it has some wierd low gear installed at some point. How would
i know for sure what gear is in it?
Old 05-30-2009, 05:43 AM   #10 (permalink)
TerryS's Avatar
when was the last time you checked the injection pump timing? On the flat you should be able to get it up well over 50.
TerryS is online now   Reply With Quote
Old 05-30-2009, 05:51 AM   #11 (permalink)
The pump was just rebuilt. I will have the timing checked today, I think it must be OK the engine really runs smooth.
Old 05-30-2009, 07:43 AM   #12 (permalink)
KevinNY's Avatar
It may be that you are just not used to the amount of gear noise and engine clatter a series make when revved up to highway speed? Remember a series is running about 2900rpm at 50 mph in 4th gear. That engine was also only rated at 60hp @4000 rpm when it was brand new, 39 years ago.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
2009 Range Rover Sport Facelift? dascrow Land Rover News 1 10-29-2008 03:50 AM
Land Rover unveils Range Rover Autobiography for British show Administrator Land Rover News 2 09-29-2008 06:25 AM
1999 Land Rover Discovery SE $6900 Carlos Land Rover Vehicles 2 06-20-2008 06:16 PM
1995 Range Rover Classic LWB w/ NEW engine Serg Land Rover Vehicles 3 11-21-2005 07:33 PM
New Delphi technologies supplied to Land Rover Serg General Land Rover Discussion 3 11-07-2005 12:37 AM
