Old 11-05-2007, 02:20 PM   #1 (permalink)
RPGreg2600's Avatar
Default Solex jets?
My rover seems to be running quite rich, and turning down the mixture doesn't seem to help much, it blows some black smoke on acceleration sometimes and the exhaust smells like gas. I have an old solex on it right now that I just swapped back on because my zenith was giving me problems (no power) The solex seems to have solved the power issues, but it seems to be using a lot of fuel.
I'm wondering if maybe I have the wrong jets installed? I have a 120 as the main jet and a 185 as the air correction jet (I think that's what it's called). Does that sound right?
RPGreg2600 is offline   Reply With Quote
Old 11-07-2007, 06:15 PM   #2 (permalink)
According to the reference book that I have, the correct jets for the 2.25 Land Rover Solex are indeed 120 for the main jet and 185 for the air correction jet. I fought with my Solex for many, many years before finally giving up and going to a Weber. I always had severe hot start issues.
You may want to check the condition of the starter unit (choke) disc & body faces. If they are leaking, fuel will be drawn through the starter, even when the choke is off. This will cause a rich condition.
jac04 is offline   Reply With Quote
Old 11-10-2007, 12:57 AM   #3 (permalink)
Series Moderator
onslow's Avatar
The solex is known for poor mpg results thats why LR went to the zenith the best carb to get is the big weber off a 2.5 D90 the little webers are good on fuel but they arent the best performers
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
