Old 01-04-2008, 07:31 PM   #1 (permalink)
TheWedge's Avatar
Default SpringOver Experience
Has anybody had any experience with doing a springover axle lift on a series rover? What in all would have to be changed? Do you have to get longer driveshafts, drop pitman arms, etc.? Just curious, I think I would like the way it would look on a series rover. Anybody have any before and after pics of this done to a series?
TheWedge is offline   Reply With Quote
Old 01-04-2008, 08:33 PM   #2 (permalink)
KevinNY's Avatar
You can fit as big a tire as a series can turn under a series with parabolics without going SOA.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
KevinNY is offline   Reply With Quote
Old 01-05-2008, 10:46 AM   #3 (permalink)
msggunny's Avatar
Gallery: 5
Here is some info on a spring over:
Increasing Land Rover ground clearance
Kevin's right though, unless you are wanting to do a powerplant change you wont be running much more than a 33in.
If you want to go the big tire route, plan on lots of mods and a new engine.
Stock gearing is good enough for 32's and if you put some HP mods on your engine, 33's. anything more will make your little 2.25 wheez to death.
But if you want to try, go for it and let us know how it goes.
77 SIII 88
97 D1 5 speed
91 D1 5 speed (the first, but gone )
When god gives you lemons, find a new god....
msggunny is offline   Reply With Quote
Old 01-05-2008, 03:30 PM   #4 (permalink)
TheWedge's Avatar
I was thinking of doing it more for looks than running bigger, wider tires. I love the look of tall Skinny tires. I just thought it would look good with a few extra inches of lift. Maybe I just can't leave well enough alone. The link above does give some good info though. Thanks for the input.
Old 01-14-2008, 08:57 AM   #5 (permalink)
XtremeMarine's Avatar
I am in the middle of a TALL landy. SOA conversion, Parabolic springs, and Military shackles on all four corners. Going tall and skinny as well. 35 x 10.5 x 16 Interco Boggers on stock series 16's, with welded on beadlocks. The hard part is all of the little things which you need to get. And the 800.oo for GBR parabolics with greasable pins.
Old 01-15-2008, 05:57 PM   #6 (permalink)
TheWedge's Avatar
I'm still kicking around the idea of doing it, but haven't taken the plunge yet.
Old 01-16-2008, 08:26 PM   #7 (permalink)
If you want it to look better, and taller, get rid of those stupid rocker panels. If you have the early 4" ones, your ride will look 4" taller and 2000 lbs lighter without them. You loose about 8 pounds real weight. Get wheels that put the tires out near the fender too. Big improvement in looks.
(Stupid rocker panels? Is my opinion showing through this text?)
Greg S is offline   Reply With Quote
Old 01-17-2008, 04:00 AM   #8 (permalink)
TheWedge's Avatar
Well, one more reason I was thinking of doing it, I have a set of wheels on the way to me now that are 19.5"x6" and my tire guy can get me 19.5 aggressive tred tires pretty reasonable. I always liked the look of the Georgia power trucks (local power co. back in Ga.) from the mid to late seventies because they had big lifts and 19.5" wheels and tires that were tall and skinny. Those things would go anywhere and they looked damn cool in my opinion. Like I said, I can't leave well enough alone. I'm a habitual tinkerer.
Old 01-17-2008, 04:40 AM   #9 (permalink)
Ian Matthews
p76rangie's Avatar
Just put Volvo Portal axles underneath it as in this Defender.
Old 01-17-2008, 06:31 AM   #10 (permalink)
KevinNY's Avatar
You are going to create drive line angles that are going to cost you money to work around as well. Probably need a CV rear shaft, spring wedges to tilt the pinion up, longer shocks etc.
Experience with Great Lakes Warranty Co.? discoIImurf Discovery Series II 0 02-26-2007 04:36 PM
Land Rover experience scotth Discovery Series II 11 01-30-2007 11:33 AM
Land Rover Experience (UK edition!) Jolly (UK) Show it off 20 09-11-2006 02:25 PM
The Range Rover Experience TAZ Range Rover P38, Mk III and Range Rover Sport 32 07-07-2006 01:25 PM
OCC does Land Rover Experience RickyRover The Lounge 6 12-05-2005 11:01 AM
