Links
Old 03-18-2006, 04:20 PM   #1 (permalink)
Question Springs for Diesel conversion
Hi Guys,
I'm about to put a Prima 3300 diesel into a 1972 series 3 which already has had an upgrade of a 2.5 NA petrol. I've also got a 1976 2.25 NA diesel which I've just replaced the front springs on.
I notice that the diesel springs are a lot bigger on the old diesel.
What I want to know is - Should I replace the petrol springs with heavier ones for the modern diesel - which is lighter than the old lump?
I would go for parabolics if I could afford them. Is there anything else I should know about? - has anyone else done this conversion?
Cheers.
Richie_asg1 is offline   Reply With Quote
Old 03-19-2006, 03:26 PM   #2 (permalink)
Series Moderator
onslow's Avatar
Originally Posted by Richie_asg1
Hi Guys,
Cheers.
Im a little confused as to what the engine is
The prima is the 2 litre lump out of a montego which is made by perkins
or its a 3.3l perkins 4203 not sure which
If its the prima no need to change springs
if its the 4203 you will need diesel front springs as a minimum as they weigh heavy
