Old 03-04-2008, 06:28 PM   #1 (permalink)
Nic
Nic900's Avatar
Default Starting dog removal
I have two questions;
1 - is is really necessary to remove the radiator to change the front timing cover oil seal coz it doesn't look like it to me?
2 - What size is the starter dog (crank handle dog), I want to try and get a deep socket to get this off.
Cheers
Nic
What happens if I turn this .....oh
Nic900 is offline   Reply With Quote
Old 03-05-2008, 05:08 AM   #2 (permalink)
pickuprover's Avatar
I always remove the rad to do that. If you are lucky, the previous owner has replaced the rivets on the mud gaurd with the screws, so you do not have to pull the whole timing cover off. I suppose you might be able to pull the starter dog and replace the seal without the rad off, but I usually just pull the rad as I hate having to reach around corners to try and do things. I think the screwdriver might be hard to get between the rad and the mud gaurd, and I would hate to put a tool through the rad......
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 03-08-2008, 05:22 PM   #3 (permalink)
Nic
Nic900's Avatar
Fare point, thanks.
Anyone know the size wrench/socket that fits this wee beasty?
LR Disco II Starting issues? LRDisco2001 Discovery Series II 5 08-03-2007 12:21 PM
Heater, coolant leak question for 2000 P38 Dburgoyne Range Rover P38, Mk III and Range Rover Sport 8 02-23-2007 01:47 PM
Intermittent starting problem - revisited... 9dawgs Discovery Series I 5 11-15-2006 04:32 PM
Trouble with starting TYLOUIE Discovery Series I 3 10-20-2005 01:29 PM
starting trouble for the new guy... lastsaturday Discovery Series I 9 09-10-2004 06:38 PM
