Old 02-14-2006, 10:53 PM   #1 (permalink)
Question Steering Tie Rods
I am refurbishing a Series IIA 1971 with braganjackson11 and we are replacing the steering tie rods. The ones I purchased seem to fit, but are not genuine LR parts. My question concerns the fastening nut supplied (different threads than original). It is a nylock nut raher than a cotter pin castle nut. Will that be okay, or should I return these and get the LR brand? The originals are copper coated shaft, the new ones are steel, it seems. Thanks for the repy!
Greg
bamarover is offline   Reply With Quote
Old 02-15-2006, 07:24 PM   #2 (permalink)
Bogatyr's Avatar
Default that's fine
bamarover,
That's fine to use a locknut, no need to return the part. Make sure you use a lot of anti-seize when assembling. Also, I'm not sure if you got the greaseable ones (QH I believe) or not, but that's what I'd suggest.
Bogatyr
Current Rover Fleet:
Old 02-15-2006, 10:14 PM   #3 (permalink)
Default Zerk fittings
Okay, aounds good! Theses do not have zerk fittings. The ones i took off didn't have them, so I didn't think to ask when I ordered. Do you knw of part number, or source for one with zerk. I wonder if they are interchangeable with US auto parts supplier tie rod ball joints? They would be inexpensive.
Greg
Old 02-16-2006, 08:55 PM   #4 (permalink)
Bogatyr's Avatar
bamarover,
Sorry, no part number, but I do know I bought the set of 6 greaseable tie rod ends from BritPac for $99...that was a few years ago, so given 2% inflation, they are prolly $150 now...I'm not sure who else sells the greaseable ones. Not that it's really a big deal, since you have a new set, just use them and then when the time comes to replace...go greaseable...
Bogatyr
