Old 02-03-2005, 04:25 PM   #1 (permalink)
Default Suspension Lift Options
HI
I want to lift my SIIA Diesel for the minimum amount of cash, is it possible and how hard is it to do a spring over axle like a toyota hilux where the springs sit on top of the axle instead of hang underneath.
All info gratefully received, what are the pitfalls?
TA!
SIIA-Pilot is offline   Reply With Quote
Old 02-03-2005, 05:22 PM   #2 (permalink)
Bogatyr's Avatar
SIIA-pilot,
Hmm, while a spring over might be nice...it's not as easy as just doing it...you'll need custom driveshafts, new brake lines, some kind of fabricating for the ubolt/spring plate setup...
And what's that gonna get you, another 2-3 inches of instability?
I'd say just put parabolics on it and be done...no custom fab work needed and if your tires are skinny enough, as they should be, plenty of articulation.
If you really need another inch or so after that...consider some extended shackles...but I'd still be concerned about the propshafts and brake lines...
Bogatyr
Current Rover Fleet:
Old 02-04-2005, 03:24 AM   #3 (permalink)
Put parabolics on - I have just done that and got another 1.5 inches at the back. Having said that, the already noisy prop has got very noisy, so it is turning out to be a bit more expensive than I first thought!
edwardatherton is offline   Reply With Quote
