Nut Futzer
I just picked up my series 3..
The clutch is supposed to have less than 10k mi on it. But it slips horribly. Possibly contaminated.. It sat for a long time.. about a year and a half... in a very wet area.. But I'm not ruling out oil. Any suggestions other than popping out the tranny at which point replacement would be the smart bet anyway.. Any inspection cover on these things? Any tips appreciated. |
Have you bled it yet?
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
Nut Futzer
I have a few things to try after some searching
Bleeding it seems to be more of a clutch sticking thing.. but I'll try it.. That and adjusting the jam nuts in the clutch master cylinder. INterestingly enough.. from pushing on the clutch.. I really didn't expect it to be hydraulic. Its pretty darn firm. |
jimfoo
Does the pedal have any free play? If not, that could be the problem. It needs some free play or the valve inside will hold pressure in the slave. Or if the Ser 3 has a pushrod adjustment, I'm not sure, it could be off.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
Nut Futzer
In case someone runs into this thread in the future.
It appears the throw out bearing slipped off the fork during assembly and got jammed .. it couldnt move all the way back and was forced against the pressure plate. Partially disengaging the clutch from the flywheel. All the parts were new.. but it still sucked. When I took off the transmission.. the throwout bearing was still jammed onto the clutch fork 90 degrees off. Use the plastic staple when assembling the clutch (or a piece of tape or something.. apparently you can assemble it wrong and not know it. Last edited by zed : 04-02-2008 at 12:39 AM. Reason: add pic |
| Thread Tools | |
| Display Modes | |
| Comments/Suggestions [Post Here] | rmuller | Tech & DIY | 29 | 04-20-2007 06:33 PM |
| clutch 1965 series IIA | captcory | Series Land Rovers | 3 | 05-14-2006 12:40 PM |
| Replacing A/C clutch pulley | LAYDOUT777 | Discovery Series I | 3 | 03-27-2006 02:25 PM |
| How viscous would a viscous clutch get if a viscous clutch could get viscous???? | 62sunbeam | Discovery Series I | 2 | 08-29-2005 11:05 AM |
| LT95 Gearbox (4 speed) Clutch Problems....... | neejah | Defender | 1 | 01-14-2005 05:54 PM |
