Old 05-05-2008, 05:13 PM   #1 (permalink)
Default turbo 2.25L
I am a mechanical engineering student at union college and i have been thinking about a project of adding a turbo to a 2.25L gas motor. I feel like it could be interesting and I know that someone used to do it. I have thought about the fuel system and considered switching to a simple efi system. I went to look for turbos an found them for 3 or 4 hundred which seemed cheap. I am unsure about the cam and the compression ratio. what do you think?
CliftonRover is offline   Reply With Quote
Old 05-05-2008, 05:39 PM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
be happy with 80 hp that comes from the motor normally.
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-05-2008, 11:32 PM   #3 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
The low compression would be good for a turbo, but I'd make sure you have a 5 main bearing engine. That and be prepared to go through lots of exhaust valves as they seem to burn/break easily. The cam is probably good as there is no overlap from what I remember. You could even take the oil for the turbo off the line to the head if you needed. BTW, the 77 normal hp was at the crank, not the wheels. 80 at the wheels is sweet however!
Jim Hall
obstacle.” Michael
Old 05-06-2008, 06:24 AM   #4 (permalink)
XtremeMarine's Avatar
I agree with the premise that it would be a good project. Get an 84-85 5 bearing longblock. Get hardened valves, and make sure the exhaust valves are sodium filled for heat issues. Get some HD, or titanium valve springs. "T" the oil line to the head, just because it's easier. I think your biggest problem will be designing an exhaust manifold that will allow mounting of the turbo, and still have clearance for everything else. One thing I have always hated about engines with the intake and exhaust manifolds so close to each other. Great idea. Go for it, and good luck.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 05-06-2008, 08:54 AM   #5 (permalink)
thanks, it is my job to mess with things being an engineer. it might be a while, but hwere is the best place to find a 5 mb motor?
Old 05-06-2008, 11:00 AM   #6 (permalink)
The UK. lol. They came out mid 1982 year, and were used in the SIII until it's end in 1985. Maybe some early 90's in 86 might have had them, but I believe the 2.5 was used in all but maybe the prototypes.
Old 05-06-2008, 09:39 PM   #7 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
I thought most if not all SIII's had the 5mb engine, though maybe I'm wrong.
Jim Hall
obstacle.” Michael
Old 05-07-2008, 08:53 AM   #8 (permalink)
I've got a mid-year production 78', and an 81' SIII 109's in the driveway right now, both with 3MB engines in them. Both original to vehicles. My info was based on info gathered on lr4x4.com, and originally posted by Mrs. Turner at Turner engineering.
Old 05-07-2008, 09:51 AM   #9 (permalink)
antichrist's Avatar
DAP carried turbos for the 2.25 back in the 80's. Al had one installed on an 88. No idea if they are still available. Ring them up and ask to talk to Al.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
turbo a vette without a turbo! hilarious!!! stolenheron The Lounge 6 11-13-2007 07:45 AM
Turbo whistle keith organ Defender 4 10-25-2007 07:35 PM
200TDi - how much turbo boost 300bhp/ton Defender 5 03-16-2005 08:54 AM
Turbo??? Noise GentrysRover Discovery Series I 2 02-04-2005 02:52 PM
turbo whistle update Andrew1002 Discovery Series I 1 09-29-2004 06:51 PM
