» Sponsors
» Sponsors
Old 10-06-2009, 09:20 AM   #1 (permalink)
Default Very odd techy transmission question
I am doing a strange project and had a question that hopefully someone can answer for me.
I am rebuilding a 1968 Series 2A Dormobile with a galv chassis (Marsland 1-tonne) Salisbury axles, a 200tdi (Defender) motor and (here's the strange part) a ZF4HP22 automatic transmission.
The transmission is from a v8 Disco 1, and the question I have is what parts do I need to mate it up to the 200tdi?
I am trying to find a partno for the ZF4HP22 tranny to 200tdi bellhousing, as well as the torque conveter, flex plate and any bolts that go with it.
My problem is that I am in North America and there is very little information on that combination (as well as being rare as rocking horse sh!t in the UK).
Any takers?
Thanks!
Don
DonFromWhitby is offline   Reply With Quote
Old 10-06-2009, 11:49 AM   #2 (permalink)
TerryS's Avatar
Anything can be made to bolt to anything, but I'm pretty sure the crank bolt pattern on the 200Tdi is different from a V8 crank. You could get a flexplate and TC from a RR or Disco, and have it drilled, I suppose. Another problem I can foresee, is that the governor in the ZF is not the same as one used with the diesels. Might make shifting a little funky.
Old 10-06-2009, 11:54 AM   #3 (permalink)
Thanks for the reply!
The only reason I am going with the tranny from a Disco 1 is to save a bit on shipping costs from having one that matches shipped over here from the UK.
If it is a better match-up to bring over the whole drivetrain behind the motor, I will...
Old 10-06-2009, 02:35 PM   #4 (permalink)
TerryS's Avatar
I'm envious because each of the two times I rebuilt my 110, I wanted to go automatic too. It would have been easier, as I was staying with a V8.
The 200Tdi is the best transplant for a series truck. I hope it works out for you.
Old 10-06-2009, 02:42 PM   #5 (permalink)
To the best of my knowledge it will be the only automatic Martin Walther Dormobile in the world... Should be fun!
/Don
Old 10-06-2009, 03:04 PM   #6 (permalink)
Back in a Series LR after 25 years :-)
slouzon's Avatar
I believe the auto trans and transfer case used behind the Tdi200 were geared different to take advantage of the diesels high torque/low RPM power band.
What axle ratios are you going to be running?
Steve
Steve
B]Back in a LR after 25 years!!![/b]
71 Series IIa 88
01 D2, 2" lift, CDL. RTE front bumper with 9500# Ramsey winch
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
slouzon is offline   Reply With Quote
Old 10-06-2009, 03:12 PM   #7 (permalink)
Steve
I'd have to look them up as I don't have the exact number offhand, but I am using the salisburies out of a series 3 lwb petrol vehicle (1983).
Old 10-14-2009, 03:28 PM   #8 (permalink)
9TEA's Avatar
You could try here, they developed a Series auto g.box many years ago.....
Ashcroft Transmissions
9TEA is offline   Reply With Quote
Transmission Question Zigidias Discovery Series II 16 03-05-2009 04:39 PM
Question about transmission on RRC 44Far Range Rover Classic 5 09-03-2008 08:48 AM
Transmission cooler line question BullDogSix Range Rover Classic 1 04-20-2008 08:58 PM
Auto transmission shifting question tgmiller77 Discovery Series I 25 08-21-2007 12:42 PM
Transmission question...? 01Discovery Discovery Series II 5 06-08-2007 04:48 PM
