» Sponsors
» Sponsors
Old 10-22-2009, 09:14 PM   #1 (permalink)
Default Water Gauge
Does anyone know of an aftermarket water temp gauge that would work for a 67 rover? I have the original in, but would like to put a gauge in that has the actually numbers listed on it so I know how hot it is running. I have tried one from a parts store, but the threads did not fit in the block. Thanks
Gnar1020 is offline   Reply With Quote
Old 10-24-2009, 08:38 AM   #2 (permalink)
Smokey Mountain Man's Avatar
I have a stock rover one that still works.
Smokey Mountain Man is offline   Reply With Quote
Old 10-25-2009, 07:34 AM   #3 (permalink)
antichrist's Avatar
VDO makes some that will fit, at least they used to. Smiths was OEM so they will too.
Depends on whether you want electrical or mechanical. If it were me I'd look for a dual water temp/oil pressure gauge. The were OE on the early Series.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
Old 10-27-2009, 02:09 AM   #4 (permalink)
jgkmmoore's Avatar
Default Water gauge
British Pacific has a dualie(water temp/oil press) listed right on the front page of the
Series parts' section with a pic.Does have numbers. You'll probably have to call 'em....their 'price check' doesn't work. Believe it was a Smith. Nice unit! Pressure tube for oil is seperate.....
Regards,
Jeff
jgkmmoore is offline   Reply With Quote
Old 10-27-2009, 07:43 AM   #5 (permalink)
Bmohan's Avatar
It been my experiance that when the BP price check doesn't work the item is out of stock.
'04 Disco SE
'72 SIII 88
Bmohan is offline   Reply With Quote
Old 10-27-2009, 03:08 PM   #6 (permalink)
jgkmmoore's Avatar
Default 'out of stock at BP'.........
Same here.....just takes me longer to catch on I guess.
Hehehe...didn't associate the two things at all. Will ask next time I order.
Makes perfect sense.......these computing things are just too much. Ya don't even have to count or spell anymore.
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 07:33 PM
[Off Road Driving] Wading Disco Tech & DIY 0 02-14-2007 05:02 AM
[ALL] Detailing FAQ's + Technique Disco Tech & DIY 0 01-08-2007 04:31 AM
Off Road - Wading Disco Off Road 4 08-17-2005 04:19 PM
