Check that you have rad fluid..... IF you have rad fluid, wash out your rad as you probably have gunk in the fins preventing the air from getting through and cooling the rad.
As for the engine.... when the gauge is in the red, STOP THE TRUCK!!!!!!!! you probably have seized the engine... at least you have burnt your head gasket by the sounds of it. NEVER RUN AN ENGINE THAT THE TEMP GAUGE SAYS IS TOO HOT!!!!
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved...  LOL!" Jellijo
