Old 01-31-2007, 06:08 PM   #1 (permalink)
Question what do i painting the differential housing with?
i need to paint the differential housing for my rover i have cleaned the housings with a wire brush and there is practically no dirt or grim on them.
I wanted to powder coat them (the rest of the vehicle will be powder coated) but i was told it is not a good idea to take them apart is this true? would pro-15 be the best option? please advise.
Thanks,
Mat
onecross is offline   Reply With Quote
Old 01-31-2007, 06:53 PM   #2 (permalink)
Super Moderator
Disco's Avatar
Powder coating is not the way to go. It chips too easily and eventually your diffs will look like sh*t. Then, you will find it impossible to find a sandblaster willing to restore it, as the powdercoating does not blast off like paint, it sort of melts off.
Old 02-01-2007, 05:35 AM   #3 (permalink)
pickuprover's Avatar
POR-15... then two coats of any metal paint.....
Andrew Barr.
1972 Series III 109.
"the Tin Turtle"
"However, that was his ploy and I caved....totally caved... LOL!" Jellijo
pickuprover is offline   Reply With Quote
Old 02-01-2007, 06:11 AM   #4 (permalink)
So far have been happy enough with por-15..... sprayed some of the larger parts, brush painted many of the smaller bits and it's stayed well......
Dave
dav1551 is offline   Reply With Quote
Old 02-01-2007, 02:47 PM   #5 (permalink)
POR-15 is not uv stable, and you need to overcoat it with another paint....
Andrew Barr.
"the Tin Turtle"
Old 02-01-2007, 03:04 PM   #6 (permalink)
Thanks, for the advise i will be getting POR-15 and overcoating it
Old 02-01-2007, 04:04 PM   #7 (permalink)
MPi-KMS-72's Avatar
It might be worth trying Eastwood's Rust encapsulator:
http://www.eastwoodco.com/jump.jsp?i...ORY&itemID=374
Here is a reprint of an article from Auto Resorer about it.
http://www.eastwoodco.com/jump.jsp?i...Y&iMainCat=688
http://www.eastwoodco.com/jump.jsp?i...mType=CATEGORY
Matt Nelson
1944 Willys MB, 1965 SIIa 88", 1971 SIIa 88", 1972 SIII 88" (gone to Chris Miazga), 1975 Ex-MOD 109/Ambulance, 1989 RRC...
Well 2nd best anyway...
MPi-KMS-72 is offline   Reply With Quote
Old 02-01-2007, 04:36 PM   #8 (permalink)
Get in, hold on!
toyota_jon's Avatar
por-15 is the way to go they also sell a uv sheild as well. a lot of yota guys use it, because rust is a big problem with our trucks
I love Hillary Clinton saying " We all need to work hard for common good " I think Stalin said the same .
-TsiArt
The Garage-
1989 Mercedes 190D
1985 Toyota 4Runner
1985 Subaru GL wagon
toyota_jon is offline   Reply With Quote
Old 02-01-2007, 05:48 PM   #9 (permalink)
Thumbs up Por-15
Not to be redundant, but POR-15 is what we did. A note of caution: Be sure and do the whole process with POR-15. Sandblast (or whatever you choose to get to bare metal - not getting to bare metal defeats the effectiveness), Marine Clean degreaser spray-on, hose off, let dry a day, Metal Ready etching solution, hose off, let dry a day. Now POR-15. Brushing smooths out really nicely. Wait a day. Top coat with a self etching primer and paint of your choice or use their Chassis Topcoat. You won't be disappointed with the outcome.
Failure to follow their entire process limits the effectiveness of POR-15. Follow it and the stuff is some kind of corrosion resistent. We used it on another vehicle over 3 years ago and NO rust yet.
We used it on swivel ball housinge, pitman arms, brake drums, door frames, and bulkhead, as well.
One final caution: If you get it on you and let it dry, you are going to wear it awhile. I didn't believe it. Beleive it.
visit www.por15.com for more info.
Good luck,
Greg
bamarover is offline   Reply With Quote
