OK....first off...i haven't posted in forever...been really busy.
For about the past year we've been having problems with the brake pedal going dead...once it was a leaky fitting...next it was air in the lines...then we realized that our mechanic put in DOT 3 brake fluid from the start since he didnt know about the importance of using the girling/castrol. So we finally figured out that the brake fluid was causing the problem. We rebuilt the master cylinder and flushed the system thoroughly with the new fluid. That fixed the problem for a while...then i lost pedal again. When i did have pedal it was pulling to the right, so we suspected the right front wheel cylinder as being the problem, since it had not yet been replaced from the beginning. I replaced that, and that solved the problem temporarily. Now we are back to the same problem. I need to rebuild all the wheel cylinders. Long story short, the parts houses have the kits, but they list them as being front and rear specific. Is there any real difference between the front and rear cylinders other then the way the fitting is cast? Besides that...anything else i could try to fix the brakes...? |
I just checked the Rovers North catalogue and they are different part numbers. I know that the cylinders are different on every corner and I am guessing that the bore in the cylinder is different front and back to "balance" the system better.
My 1964 88" has rear backing plates, shoes and drums on all four corners, but the cylinders on the front are still from the fronts and I think Mark Nault from Wise Owl mentioned this specifically because it is important. Check your cylinder bores and hopefully they won't be as bad as mine were. I had to buy a hone. Oh well, at least I have one now.
1964 Series IIA 88" 2.25 L Petrol some rust, not one straight panel
#3 (permalink) | |
Series Moderator
Secondly general rule of thumb for series brakes 109 lwb 2.6/1 tonne fronts are the biggest followed by standard 109 fronts then 109 rears which are the same as 88 fronts then 88 rears,a small number of landrover brake master cylinders can only be bled with a compressed air brake bleeder although I find this to be most effective on all landrover vehicles.
Current fleet 86 90 V8 in bits 86 RR classic Under repair 94 Disco TDI 3dr ex-police 256k and still going 80" coil sprung V8 auto Trialer in progress 71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine Stuff I have had at one time or another 76 S3 LWB 65 2a ex mil swb 71 2a swb safari 67 2a 1 tonne TACR 57 S1 V8 SWB 81 S3 SWB diesel 82 s3 SWB diesel 82 RR 2 dr perkins diesel 83 RR 4dr V8 84 RR 4dr V8 LPG 83 RR 4dr V8 LPG "in vogue" 88 RR gm 6.2 V8 Diesel 89 RR 3.5 mazda TDi 75 S3 LWB stationwagon 75 S3 2.6 LWB 86 110 2.5D 91 disco V8 91 disco TDi 89 disco V8 81 RR isuzu 2.8 TD |
forgot to mention i have a 65 IIa 88...so its more worthwhile just to get all the cylinders replaced?
Also...as of now i have zero brakes...its a miracle i havent gotten into an accident...so theres no such thing as streching it anymore...AB sells all four for around 100 bucks..but they arent the genuine girling...worth it or not? |
Yes replace all wheel cyclinders, especially if they are aluminum cast ones, as you cannot really hone the cyclinders. As well, you might want to replace the flex hoses, sometimes they get weak which allows the tube to swell, taking fluid and power away from the cyclinders. If they have never been replaced, I might order them as well if I were you.
The other thing to check would be the cams. Although some will say this never happens, it has to me, so.... The snail cams set the distance of the pads to the drum. If one is closer to the drum, it contacts first, and causes the thruck to pull. You said that rebuidling the cyclinder temporarily fixed your problem, but maybe it was that the cams are vibrating one brake tighter, and the other side loose. (definately more noticeable if this is on th front.) If there is not sufficent tension on the snail cams, then replace....
Andrew Barr. 1972 Series III 109. "the Tin Turtle" "However, that was his ploy and I caved....totally caved... LOL!" Jellijo
Adjusting, (or at least checking) the cams is VERY recommened. I did new shoes, front drum, flex lines and rebuilt front cylinders last fall. I finally took it to my mechanic because I just couldn't get it bled worth a damn. But now, it brakes about as well as my 4Runner.
Makes me wonder how bad my 4Runner brakes have gotten. Looking back, if I had more money last year, I would have liked to go for new cylinders, as I imagine my home done hone job couldn't have been top quality. But no sign of leaks yet. ![]()
The rears are 1" dia, fronts 1 1/4".
You can hone the cylinders if done properly. For $100 I'd probably just replace them all. For a bit more, replace the MC as well. Definitely replace the flex lines unless they are near new. Old flex lines are one of the biggest culprits for soft pedal. They may look fine, but internally they are swollen, and your pedal travel get's used up pushing the lines back to orginal size, with little left to move the cyl pistons.
Tom Rowe Atlanta, GA Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 |
![]() Join Date: Dec 2005
Not to get too far off track but, I was told in my Hydraulics Brakes session at college, that you can mix DOT 3 and DOT 4, the only difference is that DOT 4 has a higher boiling point than DOT 3, but not by much. So I am not sure why DOT 3 is would affect the brakes in the hydraulic action.
They do have this stuff called DOT 5 which is like a synthetic brake fluid used in high speed/high performance motor sports, and that is purple colored. It has a rather high boiling point, and cannot be used in a conventional system or more-or-less mixed in with DOT 3 or 4. They also have this stuff called DOT 5.1 which can be mixed with DOT 3 or 4. Just my two cents. ![]()
Pat Albaugh, Midwest Moderator "Diffage" -the point at which the truck's differential makes contact with the ground. http://www.cardomain.com/id/RageRover42Visit my RRC and others here!(updated as of September 15, 2006) 1995 RRC LWB -LT265/75R16 Pathfinder All Terrains -RTE 2" Lift Springs -Pro Comp ES9000 Shocks (from DAP Enterprises) -KMC Front Diff Guard -4 Desert Fox 55 watt Lighting -Radio Shack CB Radio (never know when signal fails on a cell phone) -2 Halogen Super Sport 100 watt forward lights -Brush Gaurd, meant for a Jeep Grand Cherokee, now fitted to the RRC -Lowe's Special "Homemade" Snorkel -T-Case out of an 92' RRC |
#9 (permalink) |
Pat,
The problem with regular DOT3 in a series is it can eat the high natural rubber seals. You need Girling or Castrol LMA OR Silicone Brake fluid. The Clay, The wheel cylinders are a different size F+R because it is a sort of brake proportioning. They are interchangeable- that is you could swap Cylinders F to R but you really don't want to do that. I honed the cylinders I had on my 1965 88"-they were old, I'm not sure how old but after careful honing and new seals they've lasted another 10 years. Usually I find that the major cause of replacement around here is broken and seized bleeders/fittings. The bores are almost always recoverable as long as they aren't too pitted, if you flush your brakes frequently or use silicone brake fluid it really cuts down on the amount of water in your brake cylinders and hence on the corrosion in them. |
#10 (permalink) |
Matt, yeah now I understand what you're saying. I also forgot too that the Series Rovers had 4 wheel drum brakes.
![]() Also I didn't exactly know that you can overhaul wheel cylinders too. I know that overhauling a caliper is a compromise to buying new ones, didn't know you could also do the same with wheel cylinders.
#11 (permalink) |
Make sure you check to make sure that the cylinders are cast iron, not aluminum if you are planning on honing them.... (a magnet will tell you which is which if there is a question..) you cannont use a brake hone on the aluminum ones... (although if they are not in too bad of shape, a scotch bright pad and some very, very fine emery cloth has been used, but only for a quick fix to get you home...).
#12 (permalink) | |
Series Moderator
DOT3 is fine in any LR product it will NOT affect seals in anyway the DOT system is only a way of grading performance,hence DOT 2 and DOT 3 fluids where the original grades used by landrover so mixing them is fine just be carefull with some fully synthetic oils as previously stated and some vehicles like old jaguars used a special mineral oil which is to be avoided (not easy to come by anymore anyway)
#13 (permalink) | ||||||||
no that is actually not true- at least here in the USA. They are performance grades not compositional gradings. Generic USA DOT3 can and has wreaked havoc with Series Land Rover seals here in the USA for many years. This might be an issue only with USA DOT 3. I don't know about UK DOT3 products but I do know I've seen seals left in samples of different fluid and the US DOT 3 was clearly not compatible. Like all things it might vary by brand of fluid, and by the composition/source/brand of the seals. A well meaning friend of mine happened to fill my resevoir with Walmart "tech" brand DOT3 last summer and my clutch hydraulics took a crap shortly thereafter. I've known many other people who have run into the same problem so there definately have been some compatibility issues. Quote:
#14 (permalink) | |
#15 (permalink) |
You really wouldn't think this would be a problem, especially in today's litigation prone society. I was always sceptical of the warnings myself. "surely this must have been solved long ago? This is probably the continuation of a 30-40 year old issue that has evolved into a wife's tale..."-
Maybe it has finally been solved but I know I've seen seals damaged and hoses swelled so much there was no room for fluid to flow through them. Maybe we just have really crappy DOT3 here in the States? Maybe some vender's here sell crappy seals that originate in India or Thailand or some other place where they are natural rubber? Maybe some people have used NOS seals that were 30 years old? |
