Old 02-07-2005, 02:15 PM   #1 (permalink)
Default white smoke!
I have a series III land rover and theres a lot of white smoke coming from the exhaust. My dad said the timing chain might have streached. So I got a new one and we put it in. We think the timing was out by maybe a tooth.. But i havent put it back together yet (its too dam cold!)
Is there anything else that might be causing the smoke? And do landys always give out a lot of smoke?
mr andy is offline   Reply With Quote
Old 02-07-2005, 02:36 PM   #2 (permalink)
My 2.6 L series 3 doesn't give out much smoke at all, mind you I rebuilt the engine not the long ago. I dunno what could be causing it though. Have to see what the more knowledgable land rovers have to say, I'm still a novice
Dick
DickFox is offline   Reply With Quote
Old 02-07-2005, 07:59 PM   #3 (permalink)
Bogatyr's Avatar
landy andy,
A lot of white smoke usually indicates that water is entering the combustion chamber...ie, a coolant leak, usually attributable to a head gasket problem.
To make sure a compression and/or leakdown test would be in order...or you could run a used oil analysis to check for coolant in the oil.
In any case, check on it ASAP as ethylene glycol isn't too friendly to bearings...
Bogatyr
Current Rover Fleet:
Old 02-07-2005, 09:12 PM   #4 (permalink)
Rule of thumb.
White smoke is coolant
Blue is oil
Black is fuel.
Sorry but you are looking at some head gaskets.
Mike J.
Old 02-08-2005, 02:57 AM   #5 (permalink)
My 2.25 petrol smokes a lot for several minutes but clears completely - it seems to do it more on gas than petrol for some reason.
How long does it smoke for? Does it clear completely? What engine is it?
It does sound like head gasket though - thats the most common cause.
edwardatherton is offline   Reply With Quote
Old 02-08-2005, 12:44 PM   #6 (permalink)
It's a 2.25 diesel. I was planning to take the head off anyway. I have a new gasket set in the garage. Is there anything else i should check whilst i have the top off? Its 26 years old (i think), and has probly never been opened up in its life..
Old 02-08-2005, 03:18 PM   #7 (permalink)
jozg44's Avatar
If the engine's a diesel, it may be the injector pump that is at fault.
If the injector pump is over-advanced or not balanced correctly, the fuel just swirls around in the cylinder without burning properly, then chuffs out the exhaust as blue/white smoke.
Having said that, it sounds more like a head gasket to me, but just bear it in mind
Jack
jozg44 is offline   Reply With Quote
Old 02-08-2005, 10:20 PM   #8 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
First (and least trouble and expencive) drain your diesel tank and clean it out with "fresh clean" diesel.
It might only be that you have water in your tank and that is the reason for the smoke! Some guy might have gotten rainwater in his tank and sold you some diesel with water in!
Moeras is offline   Reply With Quote
Old 02-08-2005, 10:26 PM   #9 (permalink)
Profesional Hunter
Originally Posted by Disco Mike
Rule of thumb.
Blue is oil
Black is fuel.
Mike J.
Very true!
Also consider Rings & Piston sleaves. If they are worn you will have Blue smoke. The way to see this is that the Enjin will use oil faster than normal. Fill up the oil, go for a long drive (Take a back up car along) if the oil level dropped significantly during your drive your rings is worn. The oil is burned in the combustion chamber.
A compression test will also tell you that something is wrong in you pistons, but it might be that you have a blown gasket.
Old 02-09-2005, 12:12 PM   #10 (permalink)
hmm, I had herd about the fuel pump thing too... The oil level never really went anywhere when it was idiling. I'll try the gasket.
I had drained the tank and refilled it too.. still the same problem..
Old 02-09-2005, 12:57 PM   #11 (permalink)
would it be worth changing the rings while im at it? Or is it too much hassel?
Old 02-11-2005, 06:08 AM   #12 (permalink)
Bogatyr's Avatar
landy andy,
Hmm, it depends on how far "into it" you want to go. Do a compression test before pulling the head if it is indeed a head gasket problem and that should tell you if you might as well work on the lower side of the block...
Bogatyr
edit: Hmm, not sure about diesels...I'd think it would be the same in principle though...also, read up on the green bible...what's the situation? Scoring on the cylinder walls? Other symptoms?
Old 02-15-2005, 01:04 PM   #13 (permalink)
well, i took off the head today, there was a chunk of gasket missing. It was easier than I expected. I cleaned it all up like, but its not back together.
I noticed on the inside of the cylinder head (where the valves are) theres a load of dents as if someone battered it with a screw driver.. weird..
Old 02-15-2005, 10:46 PM   #14 (permalink)
Profesional Hunter
Could be where the part of your Gasket went to. The small metal ring in the gasket (around the pistons) is hard enough to do that kind of damage, so if part of that is missing it most likely did that.
Is it possible that you can post photos of the Damage?
Better take that to a qualified machanic to see if it is OK or should be Fixed/replaced.
regards
Old 02-16-2005, 02:13 PM   #15 (permalink)
well the damaged cylinder head wasn't the one where the gasket was dammaged. I cant take photos, coss i put it back together today. lol. It wasn't much like, probly be ok.
