Wiring Harness is Fried - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 12-17-2010, 12:43 PM Thread Starter
Quoted: 0 Post(s)
I am sad to say that my wiring harness has gone to the crapper. Has anyone on here ever used a Painlees Performance wiring kit? I know that they make them for early broncos and land cruisers but no rovers. I was thinking of using one of their universal kits. If anyone has ever used them any information that you could give me would be great.
Paydan is offline
post #2 of 8 (permalink) Old 12-17-2010, 03:58 PM
antichrist's Avatar
Quoted: 3 Post(s)
http://www.britishwiring.com/Lrover.PDF
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
74 Lightweight - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
antichrist is offline
post #3 of 8 (permalink) Old 12-18-2010, 11:23 PM
Quoted: 0 Post(s)
Yes, I used a universal Painless kit. Easy to install if you can wrap your head around the electrics. I found it easy, but for some reason traditional "car guys" always find electrics to be really confusing.
There's no ECUs or advanced electronics to worry about with a Series Rover. Hardest part is snaking the harness through the frame if you want a clean install to the rear circuits (lights, etc). Or you could just keep it outside.
It certainly upgrades the "capacity" of the electrics from four fused circuits to... many, many more depending on the universal kit. I had a GM/Delco alternator on mine, so that hooked in readily. All the circuits are color coded.
1971 Series IIA 88" Land Rover EV (Follow the conversion to EV power at my blog,
1999 Land Rover Range Rover Callaway #071
Overlander23 is offline
post #4 of 8 (permalink) Old 12-20-2010, 09:04 AM Thread Starter
Quoted: 0 Post(s)
Awesome! Thanks for the information you guys. I was looking to keep it original at first but I am leaning more and more to the Painless setups due to the easy of install and the higher capacity that they are capable of. Thanks again.
Overlander,
Which kit did you actually go with?
Thanks again.
Paydan is offline
post #5 of 8 (permalink) Old 12-21-2010, 02:00 AM
jimrr
jimrr's Avatar
Quoted: 0 Post(s)
I've heard lucas electrics called ''prince of darkness'' , ha ha. i've had 2 series 3, half a million miles, a lot of that harrowing fields, fixing fence and the rest and have never had as much as a shorted wire!!
jimrr is offline
post #6 of 8 (permalink) Old 12-21-2010, 07:57 AM
Quoted: 0 Post(s)
I agree with jimrr. (Except I HAVE had a shorted wire.) I've had a Series I, Series IIA 88 and for the last 12 years a Series IIA 109 SW and rewired a friends 109 SW, mainly by removing wires put in by PO's and resurrecting the original harness with a few splices and wires for newfangled thingies.
First, get a Delco alternator (70 amp approx) adapted in place of the generator (mind you, generators do have their benefits but 20 - 25 amp output isn't one of them). Then make sure you have 2 good grounds from the battery as original, one to the chassis and one to the engine block.
Whenever you are working on anything electrical make sure you follow and correct the ground connections as Lucas believes anything electrical requires two wires- ground and supply- VERY little is grounded to a body panel.
Check this information VanIsle Land Rover Network: Information
When you say your wiring harness has "gone to the crapper" what do you mean? It's possible it has because your Rover has had Previous Owners (PO's).
Greg S is offline
post #7 of 8 (permalink) Old 12-24-2010, 01:27 PM
Quoted: 0 Post(s)
Originally Posted by Paydan View Post
Overlander,
Thanks again.
Oh man, it's been almost 15 years since I did it with mine as part of a frame-off rebuild. It was one of the universal street-rod kits. Pick how many circuits you want... just tally up how many things you want control over to determine number of circuits. I added extra rear illumination lighting, interior lighting, fog lights for the front, electric fan, wired for a GM/Delco alternator, door light switches, rear wiper, rear window defogging element, electronic ignition, 12v auxiliary plug, second fuel tank electric switchover solenoid, rear tank gauge, rear heater blower... maybe more. It's all very robust and fully fuse protected. I stuck the fuse-box to the right of the steering wheel (LHD). There are a couple of more circuits still available. So maybe an 18-circuit kit non-keyed?
The only thing being an issue, if I recall, was the alternator connection. But I think any kit can be adapted for whatever you've got.
I had rebuilt my Rover to be more useful, not to be stock or "original". I would have gone with a more conventional replacement loom if I was concerned about originality. I think at the time, though, there weren't very many aftermarket "stock" solutions for reasonable $$$. The Painless Wiring looms were reasonably priced.
Of course, my Rover is the farthest thing from stock now... but the wiring is all good and still has extra capability if necessary.
Jeff
post #8 of 8 (permalink) Old 12-25-2010, 01:19 PM
Quoted: 0 Post(s)
These series landrovers are so simple, you can just buy some 7 wire covered trailer wire to run to the rear that would do everything you could want including electric brakes for a trailer. A little uncovered 4 and 7 wire behind the dash then some more covered 4 and 7 wire for up front and you have your own "wire harness" that is protected, it just wouldn't be color coded.. You could even get fancy and use a relay or two for the headlights, or not. Throw on a delco alternator with built in volt regulator along with a universal fuse box (with a few more fuses in it) and the job is complete.
1971 88 last of the series 2A, Series 3 trans, Fairy OD. Second owner since 1977.
Busboy is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Series Land Rovers
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Trailer wiring Harness - HELP! One and All Accessories 8 08-31-2011 04:50 PM
Which wiring harness Bimet Series Land Rovers 1 01-20-2010 05:36 PM
Trailer wiring harness fishEH Discovery Series I 1 11-15-2008 07:14 AM
What wiring harness will I need? Crankin Series Land Rovers 2 07-28-2008 07:07 AM
Trailer harness wiring 98RRover Land Rover Parts and Vehicles Wanted 0 08-10-2005 03:47 PM
You may post new threads
You may post replies
