» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Supporting Vendors > Supporting Vendor Archives > Sun Performance
Old 04-09-2009, 10:14 AM   #1 (permalink)
SunPerformance's Avatar
Default New QuickAir X 1500 and 2000!
Sun Performance is releasing their new line of compressors, the QuickAir X, which is due to release in April. These compressors will be of higher quality and faster than their previous QuickAir's and capable of running air tools. We currently have two models available and come in a hardmount or portable version:
QuickAir X 1500
- 12-Volt
- Permanent Magnetic Motor
- Amp Draw: 20 Amps
- Duty Cycle: 100% @ 100 PSI
- Max Working Pressure: 150 PSI
- Min. Ambient Temperature: -40 degrees F
- Max. Ambient Temperature: 160.6 degrees F
- Dimensions: 257L x 100W x 163H
- Net Weight: 7.72 lbs.
- Time to fill 2.5 Gallon Tank: 0-100 psi - 2 min 30 sec.
QuickAir X 2000
- 12-Volt
- Amp Draw: 22 Amps
- Max Working Pressure: 200 PSI
- Max. Ambient Temperature: 142.2 degrees F
- Dimensions: 288.5L x 100W x 163H
- Net Weight: 9.26 lbs.
- Time to fill 5 Gallon Tank: 0-200 psi - 11 min 15 sec.
PM for more information!
We Build Confidence
3605 W. MacArthur Blvd, Suite 705
Santa Ana, CA 92704
PH: 714-708-7730
FX: 714-708-7722
www.sunperformance.com
SunPerformance is offline
Old 04-17-2009, 11:29 PM   #2 (permalink)
Reptile Expert
any pics of these installed in rovers?
www.cardomain.com/ride/2650472/
www.fortmyersracing.net
www.cafepress.com/stolenheron
stolenheron is online now
Old 04-18-2009, 07:05 AM   #3 (permalink)
Deployed OIF
ArmyRover's Avatar
I have a very similiar pump I picked up at sam's club mounted in the rear of my RRC it's not bad but it's not super fast at filling 33's. I don't know if they still have any but it was about $34.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
ArmyRover is online now
