Old 05-08-2007, 06:18 PM   #1 (permalink)
Greg M's Avatar
Default 10 spline axles
Well, my front brakes were dragging, rotors looking pretty thin, and of course my swivel ball seals were leaking like a sieve, so i dove in and rebuilt it all. Lets see, i've rebuilt the engine, replaced the blower motor, and replaced the swivel seals. There can't be anything on this rig that's worse than these three. . . I think I deserve some sort of award.
Anyway, let me get to the point. With all the talk about 10 spline axles and their inherent weakness, which part or parts are prone to breakage? I would like to carry a spare. And no, i am not in the mood to upgrade to 24 at the moment.
Thanks.
Greg M
1987 RRC
Rovers haven't made it to the far reaches of the Earth worrying about warning lights.
Greg M is offline   Reply With Quote
Old 05-08-2007, 07:19 PM   #2 (permalink)
The typical part that breaks is the axle or half shaft. I wouldn't go so far as to say that the 10 spline half shafts on a RRC are anywhere near as likely to break as those found on a Series truck. However, under duress, they do break and when they do they ofter break at the diff. Unless you are doing a lot of off roading, you probably don't need to carry anything. If you break a half shaft you should be able to make it home simply by locking the center diff. That's one of the advantages of having an LT230.
If you want to buy a set of 10 spline front half shafts you need to know what kind of CV's you have. There were two types found on those early RRC's, Suffix A and B. The half shafts are different for each type of CV. IIRC the half shafts for Suffix A are 24 spline at the CV and 10 spline at the diff. The Suffix B is 32 spline at the CV and 10 spline at the diff.
If, after all of this, you are interested in a set of half shafts, I probably have what ever you need. I just haven't sold any 10 spline stuff in awhile so I would have to check.
Old 05-08-2007, 08:59 PM   #3 (permalink)
Greg M's Avatar
Thanks Paul. I suppose with the combo of a LT230 and a fully floating axle, i could pull it and make it home. I didn't count the splines on the CV's but do remember them being very "stubby" on the end, so probably the "A" (its the shorter of the two, correct?). I don't wheel that hard anyway, I was just curious. If I snap one I'll get one from you.
Greg M
1987 RRC
Old 05-08-2007, 09:57 PM   #4 (permalink)
Large Land Mammal
astateofmike's Avatar
Greg, crawl under and look at the drivers side of the fron t axel...under the sterring box area, and there is a long number with an A or B at the end...
The stub axels are all short, the "teeth" are what count...My 88 RRC had an A, and I got a whole spare set of front/rear and the stubs...Bet yours may be an A, but that number tells it all...you can see it just looking under the truck...
Well, my tires, maybe I have a bit easier a look...
" We sleep safely in our beds because rough men stand ready in the night to visit violence upon those who would do us harm." G.Orwell.
88 RRC, 2.25 OME, Truxis M/T, LR Brush Guard, QT diff guards, now dremel modified front skid plate...Hella 550 and 500, full length Brownchurch observation platform rack and various leaks and dents.....
astateofmike is offline   Reply With Quote
Old 05-09-2007, 01:55 PM   #5 (permalink)
Series Moderator
onslow's Avatar
Thanks.
In 15 years of range rover ownership ive never bust a halfshaft done a few CVs but on the whole the axles are bombproof whether 10 or 24 spline
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
